Recomended fan CFM for 305 ASAP!!
Old Oct 11, 2009 | 08:52 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
what CFM eletric fan should i get for a 305 TBI, mildly modded, w/ an all aluminum rad
should a 16" 2500 CFM do
my current fan took a dump and plus i figured out it was not what it was suspose to be
anyway i need to order one like yesterday so fast help would be nice
Old Oct 12, 2009 | 12:46 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Recomended fan CFM for 305 ASAP!!
if it does actually pull 2500 cfm(ratings of many after-
market fans tend to be exagerated),it should do
the job,i recon the stock single pulls about 2500 cfm.
Old Oct 12, 2009 | 02:04 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
here's what i have:
http://ffdynamics.com/FFD3600B.html
i have it hooked up to a Flex-a-lite variable speed controller. i highly recommend it- very good quality. it works great and pulls a lot of air. this fan, an in-tact air dam, and a 180* stat and not even close to overheating- even on a scorching hot summer day
Old Jun 16, 2010 | 06:48 PM
mikesanto70's Avatar
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
how did you mount that ffd, will it fit on a 91' 305 TBI camaro
Old Jun 17, 2010 | 02:19 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Not quite certain if the 16 7/8ths fits, but turn it around 90 degrees and it´s only 15 7/8ths high which certainly fits in a stock TBI
Anything actually pulling 2500 CFM will do. I replaced my original fan with a 2000 CFM model and it does pull more air then the stock one. I have heard several people on this forum state the original fan pulls something between 1200 and 1500 CFM.
Since my fan gave up shortly after I purchased the car I have no means of confirming this.
BlueIroc-Z
Jun 9, 2019 03:22 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
beastin91rs
Oct 9, 2015 07:38 AM
dutch930
Sep 11, 2015 06:58 AM
Ducati900ss
Sep 2, 2015 09:05 AM
