E-Fan Problem
Old Nov 10, 2009 | 09:55 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
E-Fan Problem
Okay, so I have an '85 Z with one E-Fan. The fan will not turn on and just need a little info track down the culprit.
The fan relay is up front near the battery correct? I have 12v on the orange wire, and the fan turns on when I jump the orange and the black one that goes to the fan. The brown wire with the white stripe has some voltage on it when the key is on. Is the green wire with the white stripe for the AC? I get no voltage on that one.
How is this setup supposed to work? I figure either the brown or the green one give a cirtain voltage at tempurature X, and that connects the orange a black wires through the relay, turning on the fan. What kinds of voltages should I be seeing on the brown wire?
Thanks!
Old Nov 10, 2009 | 09:56 AM
Re: E-Fan Problem
Forgot to mention... In diagnotic mode the fan turns on, so I guess the relay is OK huh?
Old Nov 10, 2009 | 02:34 PM
86Stevo's Avatar
Re: E-Fan Problem
i wish i could i help y out on this but i am posting because i have the same exact problem in my camaro its a 86 but i have a single fan and it wont turn on at all i havent checked any thing but if i figured it out i will let you no i am assuming the relay is good because i ran it unplugged and the car ran like **** and then the metering rods started working in the carb when i plugged it in
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
