That little switch on the back of a R4 compressor
Old Nov 18, 2009 | 02:31 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
On my 85 TPI Z28 I have a 2 wire plug (dk green/white and Lt blue/black wires) that is suppose to connect to a switch on the back of the ac/compressor. I'm just not sure which switch I'm suppose to have...There are three options: 1- High pressure, 2-Fan, 3-Low pressure...Can anyone advise on this? Thanks!!!
Old Jan 13, 2010 | 01:26 AM
85 ZXX's Avatar
Re: That little switch on the back of a R4 compressor
Well, after doing some digging and testing on the car...It was for a low pressure switch. it ties in with the low pressure cycle switch on the a/c drier. For now, I just tied the two wires together so my cycle switch will work the compressor.
Old Jan 13, 2010 | 01:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
KA-BOOMMmmmmmmmm
That’s the overpressure switch the - purpose of the overpressure switch is to turn the compressor off in case of overpressure.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 14, 2010 | 12:18 AM
85 ZXX's Avatar
Re: KA-BOOMMmmmmmmmm
Thank-you for the response. I found this on the web recently.
Here is the link http://www.hermantorres.com/SEARCH/SW/GM_SW_illus.html
b4ccamaro
Jun 5, 2016 01:48 PM
bryanwood74
Sep 24, 2015 09:50 PM
soarestransam
Sep 1, 2015 04:00 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
Street Lethal
Aug 13, 2015 08:28 PM
