92 v6 blower motor wire and heater core hoses
Subscribe
Dec 14, 2009 | 04:28 PM
i have a 92 camaro rs with a v6 and a 5 speed bogwarner
i have 2 questions
question 1
i need to replace the heater core hoses and i was wondering if the two hoses are form fitted or can i just get two regular hoses !
question 2
i dont have a purple wire for the power but i do have a orange wire that looks to be for the underhood light! but it looked like it was the plug for the heater motor but i dont have a light at all looks like it was never one there !
thanks again !
Reply 0
Dec 14, 2009 | 05:50 PM
Re: 92 v6 blower motor wire and heater core hoses
question 2
1) On a v6, I can't really remember but, there should be a couple molded hoses regardless. I'm sure a couple could be replaced with straight hose but, most any chain store should have/can get the proper hose fairly cheap. Not straight hose cheap but, that's up to your budget.
2) Where's the question ?
Reply 0
Dec 14, 2009 | 09:30 PM
hey db sorry about that the second question is for the heater blower motor i dont have a purple wire to plug in too it for it to turn on . but i do have a orange wire that looks like it went to a underhood light but i dont think my car ever had one! can i just use that orange wire to give the blower motor power?
i'll have pics tomorrow when i got pick up my car and the digital egrand my camaro in the napa parking lot thanks !
Reply 0
Dec 14, 2009 | 10:22 PM
No big deal.. I thought that's what you were getting at but, you never know...
If your car had (removed) a under hood light, the wire is always hot and way to thin gauge to (safely) run the blower at full speed.
Sometimes, there is wiring in a harness never used as well.
Is the blower a new problem or, something you're trying to fix since acquiring the car ?
Reply 0
Dec 14, 2009 | 11:00 PM
yeah ive only had the car about 6 months and i just started drivin last week and its starting to get some what chilly and humid here in florida so i would love to have heat or at least defrost !!
Reply 0
Dec 15, 2009 | 09:39 PM
The blower motor high speed relay should be mounted directly to the blower box (just left, looking at it from under the hood, of the accumulator [silver can]). It's grouped with the rest of the wiring from the resistor 'pack' which is plugged directly to the blower box.
Within that group of wires should be your motor (purple, 14ga) wire. If it's not in that general area, along with the other related wiring, it may have been hacked out by the previous owner.
Reply 0
Dec 16, 2009 | 04:37 PM
Here's the way my '91 looks. Older cars had a slightly different high speed relay and wasn't mounted to the blower box IIRC
Reply 0
Dec 16, 2009 | 07:25 PM
wow my heater box dosent look likt that it sorta looks like a delete box ! i'll take better pics and post them tomorrow i have a harness off a 91 and it looks like just like yours ! well i do remeber when i went to replace me serptine belt the guy at napa said some of these 91-92 came from the factory with out ac and had ac add later ! kinda like aftermarket ac kit ! i have a belt thats a lot shorter than most peoples belts for my serpentine set up and my ac was a v belt ! is that normal ?
i'll see if i can dig up some engine pics tonite while iam at work !
thanks again !
Reply 0
Dec 16, 2009 | 07:54 PM
two engine pics
before
after
hope this helps others and me thanks !
Reply 0
Feb 13, 2010 | 08:18 PM
i have a wynns frostemp aftermarket ac i found the tags a while back and located a place in jacksonville and here in tallahassee !
iam getting the car back up and running bc i need a car for work
thanks for all the help this is a great board with great guys thanks again !
Reply 0
Subscribe
