WHAT IS THIS?
Car: 1987 IROC-Z
WHAT IS THIS?
I have looked and looked but i can not for the life of me figure out what this part is, all i know is that it is hooked up to the A/C unit and branches into my throttle body. I figure its a sensor or valve or something but idk, can anyone help?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: WHAT IS THIS?
that is the heater control valve-the reason it has a port
connected to the throttle body is to circulate hot coolant
to the throttle body in order to prevent the throttle
body from icing up in certain cold weather conditions.
As far as i know,only cars from about 1987-up have
this valve.
this valve.
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
Re: WHAT IS THIS?
this valve.
this valve.
Great info , i was wondering about the same thing ...LOL
THANKS
Car: 1992 RS
Engine: Carbed 350
Re: WHAT IS THIS?
Does it have a line that runs to the throttle body? I thought the rubber tube running to the throttle body was for a PCV setup. I've never seen a heater control valve that runs coolant through the throttle body. I have seen coolant circulators that sat on top of a carb or TBI intake to help cool the air/fuel mix as it enters the intake.
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: WHAT IS THIS?
A "TB coolant bypass" is a fairly common mod; performed to reroute the coolant directly to the control valve from the intake base. Here's a link.
Re: WHAT IS THIS?
Yes, coolant runs from the front of the intake base through a short hose to the driver's side of the throttle body, then into a passage on the the bottom of the throttle body, then out the passenger's side into the aforementioned control valve.
Is this the same on the TBI 305's ?????
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
