Need help with 88 Camaro
Old Jan 23, 2010 | 03:27 PM
Justine's Avatar
Car: 88 Chevy Camaro
Engine: 6 cyl
Hi, I have an overheating problem with my 88 Camaro, 6 cyl. We have replaced the radiator (now has green coolant), flushed the radiator, replaced the thermostat (which was wasted), the thermostat housing and the upper radiator hose, which a hole burned in it when the engine got too hot). Still the engine overheats and when we started it up after replacing those things we get white smoke (that smells like steam?) from metal hoses in the engine...?
Also is it bad to spray WD-40 on the engine to clean it? When the radiator hose broke it sprayed coolant all over and then the coolant smoked on the hot engine too....
Please, anything will help as this is my only car, and I'm stuck. Thanks
Old Jan 23, 2010 | 07:04 PM
aks's Avatar
aks
Car: 92 Z28
Re: Need help with 88 Camaro
is it leaking anti-freeze at all? or is it just overheating?
Old Jan 23, 2010 | 07:28 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
Is the cooling fan(s) working?
Old Jan 23, 2010 | 08:51 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
old 2.8's were notorious for blown head gaskets >.<
Old Jan 24, 2010 | 08:58 AM
aks's Avatar
aks
Car: 92 Z28
yeah it sounds like a head gasket to me.
Old Jan 24, 2010 | 01:51 PM
Drew's Avatar
-deleted
Old Jan 25, 2010 | 06:47 PM
Justine's Avatar
Engine: 6 cyl
Hi, It's not leaking anymore that I know of, it is low right now because of the hose leak and I can't afford any more coolant until I get paid. (not driving it right now either). It just overheats. On the road in stop and go traffic it overheats in about 20 minutes. On the highway it seems to keep it cooler, but then as soon as you get off the highway it gets hot fast. Cooling fan does not work, can't afford to replace it till later. I don't think thats all of the problem. Whats an air dam? It is hard to replace the head gasket? Could part of the problem be the water pump? Thank you for your input
Old Jan 28, 2010 | 01:02 AM
Drew's Avatar
-deleted
Old Jan 28, 2010 | 08:31 PM
aks's Avatar
aks
Car: 92 Z28
I would first put in an air dam like he said earlier and get that fan fixed and see what that does.
Old Jan 28, 2010 | 09:01 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
A fan and airdam are just as importent as your tires or gas ,,without the camaro is not FULL intact and drivable.
GET IT FIXED QUICK !!!!!
Old Jan 28, 2010 | 09:05 PM
hatemail72's Avatar
Car: this and Dodge Dakota Quad
Engine: 383 tbi
Transmission: 700 R4
Axle/Gears: 3-73
what coulour was the coolant before you replaced to green??????
Old Jan 28, 2010 | 09:22 PM
Justine's Avatar
Engine: 6 cyl
I don't think it has an air dam, I can look behind the radiator to the ground with no black plastic anywhere. Coolant was .. blue, when we changed it and before that the guy we bought it from I think it was red? maybe.
Old Jan 28, 2010 | 09:27 PM
If u look from the front under your car , what do u see ?????
Old Jan 28, 2010 | 09:58 PM
Drew's Avatar
-deleted
Old Jan 30, 2010 | 04:46 PM
Justine's Avatar
Engine: 6 cyl
thanks, will look for that. under the car i can see the bottom of the radiator and some hoses
Old Feb 22, 2010 | 09:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i dont have one either, as do alot of other members here
Old Feb 22, 2010 | 10:00 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
if the car overheats because the cooling fan is not working, have you diagnosed the fan as not working, it could be a bad temp sensor, don't remember what it's called,
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
