will pcv cause overheating?
Old Feb 11, 2010 | 08:02 AM
sparkplug619's Avatar
Car: 1990 RS Camaro
Engine: 305 TBI
Transmission: T-5 stick
hello, i come from a world of inline 6. 1 head, 1 exhaust, 1 intake, 2 cams and 1 head gasket. This is my first V type engine and its still taking me awhile to adjust.
Background: I recently bought a super beater 1989 RS 305. The car is a complete mess. I bought it because I was under the impression the engine was in decent condition besides an exhaust mani.
Situation: On the way home from buying this beater the heat was at 220, which is hot but not overheating. When i got off the freeway and pulled up to the light I noticed a tiny bit of smoke steaming up the windshield, by that point my heat was at about 240 or so but i figured it was just from the bad manifold. I was only a street away so i decided to keep going, I had to go up my hill and by the time i got to the top my car was at about 250+ (the guage stops at 250 and it was waaay over the 250 mark).
The temp guage is aftermarket mechanical so im pretty sure thats close to accurate temps.
When I popped the hood the resivour was bboiling and the car warmed me up pretty good. I only looked at it for a second but the thing that caught my eye the most was the ripped pcv line.
When i get off work ill check the basics and figure out what next
Old Feb 11, 2010 | 08:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will pcv cause overheating?
The PCV system won't cause overheating. Make sure the air dam under the radiator is intact, and the fans are working.
Old Feb 11, 2010 | 09:00 AM
Car: 1990 RS Camaro
Engine: 305 TBI
I understand the fans need to be working but would the air dam cause as much overheating as i experienced?
Old Feb 11, 2010 | 09:25 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Sounds to me like your cooling system isn't holding pressure properly. Look for a small leak or bad rad cap. Worst case could be a failed head-gasket or cracked head.
Pressure checks are in order.
Old Feb 11, 2010 | 09:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I wouldn't expect the cap to hold pressure at 250 degrees.
Old Feb 11, 2010 | 10:11 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Flush the cooling system and replace the thermostat. Start from there and work your way up to what the others have mentioned: fan, fan switch, radiator cap, water pump.
Old Feb 11, 2010 | 05:17 PM
Car: 1990 RS Camaro
Engine: 305 TBI
found a big problem... the fan was not plugged in. i havent checked to see if this was why it was overheating but i know its going to keep those temps lower... im going to kragen to get some coolant and a lower temp thermostat for this san diego weather.
I also found a big bottle of stop leak in the back seat so i know its leaking from somewhere now
Old Feb 11, 2010 | 05:24 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Cool, you caught the fan issue. They also sell kits that contains a dye and a blacklight so you can find the leak a bit more easily. Maybe something to look at.
Old Feb 11, 2010 | 05:40 PM
Car: 1990 RS Camaro
Engine: 305 TBI
ya I heard of those dye kits, I also just realized that my radiator cap looks like the original cap from the factory, so thats getting replaced also
Old Feb 24, 2010 | 11:22 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Did you ever get a dye kit and find the leak sources?
Old Feb 24, 2010 | 09:29 PM
Car: 1990 RS Camaro
Engine: 305 TBI
Yup, I traced it back to my drain plug and a small crack on the bottom of the radiator.
I have a new radiator here waiting to go in... just too lazy
Old Feb 25, 2010 | 01:07 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Dang Sparkplug, this Camaro is really putting up some challenges. Have you bought a repair manual yet? A Haynes isn't the greatest but it helps. I look forward to seeing more of your progress. I'm just up the road from you.
Old Feb 25, 2010 | 04:44 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Cool deal. Good thing it wasn't the engine.
Old Feb 25, 2010 | 11:27 PM
Car: 1990 RS Camaro
Engine: 305 TBI
lol this car is definitely not too friendly but i like when they play hard to get! lol jk, but a man really builds a relationship with a car he has to get dirty under then a car he only changes oil in. imo of course
you should hit me up, we can hang out some time. how u doing with your search for the right firebird? Theres a really beautiful black 4th gen bird around my neighborhood, seen it driving back and forth today and fell in love, too bad a headlight was out lol
there is also a really cool little mustang restoring shop down the street, its fun stopping by there and seeing what they got going, they have a really nice fox body saleen in mint condition
Ya man definitely, the plastic part of the radiator had a hair size crack right on the bottom, thirdgenranch hooked me up though, good people there!
Old Mar 7, 2010 | 05:38 PM
Car: 1990 RS Camaro
Engine: 305 TBI
also found a leaky upper radiator hose. This was my fault though because when I changed the thermostat I cut a little bit of hose off and when I put it back on I realized it was barely on the water neck. The thermostat was the first thing I changed on my car and I barely discovered the leak.
Old Mar 14, 2010 | 04:29 AM
h_worker's Avatar
hi.just purchased 86 camaro was tpi now carb.had blown head gasket,had heads crack tested all ok.replaced gaskets and put alloy 4 core radiator in. wire up 1 fan with thermo stat in radiator hose.car running at 220 fan cutting in at 195 but takes 9 mins to turn off after car turned off and one side of radiator is cool as is hose but other side hot?should i run both fans on thermostat .sorry to appear dum but any help would be appreciated.thanks rob
Old Mar 14, 2010 | 05:36 AM
Car: 1990 RS Camaro
Engine: 305 TBI
Run them both on the thermostat and possibly get a lower temp thermostat. 160-180
Bubbajones_ya
Jul 6, 2024 08:32 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
