tore out AC... now I need to plug these lines
Old Mar 6, 2010 | 10:39 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I was wondering if anybody makes any plugs for this AC lines coming out of my heater box. I tore out the system since it didn't work, but I might go back sometime so I don't wanna convert the whole box. Thanks!
Here's a picture... for now I have em duct taped.
Old Mar 10, 2010 | 05:52 PM
Engine: LB9
Re: tore out AC... now I need to plug these lines
bump...nothing? I'm sure somebody's done this....
Old Mar 12, 2010 | 01:06 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Looks like they're "plugged" well enough to me. Since you already leaked all the R-12 or R-134 that was in there into the atmosphere, the harms done. You removed the compressor, so it's no longer under pressure and therefore runs no risk of leaking fluid. Granted some might remain in the dryer or lines, but not for long. Unless you want to put some metal caps on it for cosmetic reasons, the tape should be fine to keep foreign matter out should you decide to repair the system. But the system was not intended to be like that, and some moisture may find it's way in there.
Old Mar 12, 2010 | 05:00 PM
Engine: LB9
Considering that I'm a car enthusiast do you REALLY think I'm too concerned about some refrigerant leaking into the air? Well the system was empty anyway. The r-12 leaked out a looong time ago. I'd want the caps just for cosmetic reasons basically.
Old Mar 15, 2010 | 08:54 AM
Pocket's Avatar
Car: 91 Trans Am
Freon, both new and old is about as toxic as it gets. Being a hotrod enthusiast makes no difference to be being responsible
For caps, take the removed lines to a plumbing store and find some brass plugs/caps
You may have to find a machine shop and make metric pieces. I cant remember the thread type
Old Mar 15, 2010 | 02:40 PM
Engine: LB9
It's not that the freon was old is was that the system was COMPLETELY dry. No freon whatsoever. But thanks for the advice... I just assumed that some company made caps for this since I doubt that I'm the only one who's done this.
Old Mar 16, 2010 | 03:18 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
black rubber (vacuum) caps and hose clamps. You can get them in sizes of 1/2" and 5/8" that fit over hose nipples.
Infested
May 22, 2018 11:56 PM
evilstuie
Feb 28, 2016 03:33 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
