Trying to remove water pump cant remove ps bracket
Old Mar 3, 2010 | 02:40 PM
anomolee's Avatar
Hi Guys,
I have an 87 iroc, 305 tpi, ac. I've gotten all of the brackets off to remove my water pump except the ps bracket. How do I do this? I can't get this thing off. I see three bolts, 1 bottom, 1 block , and 1 into water pump. Is there anyone?
Old Dec 2, 2012 | 12:24 AM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Re: Trying to remove water pump cant remove ps bracket
Does anyone have a response to this thread? I am in the exact same spot, also with the same vehicle as aforementioned.
Old Dec 2, 2012 | 12:28 AM
anomolee's Avatar
Hi, you caught me online. I was able to get the bracket to move out of the way. Just loosen them up as much as possible and you can swing it away. I may be a little hard if it hasn't been moved in a while but you will be able to do it. It worked for me.
Old Dec 2, 2012 | 12:34 AM
Engine: LB9 | LS1
That's my issue, the bracket/pump assembly won't swing at all. I have removed the top nut that hinges the pump assembly in place, the bolt below it that allows for sideways adjustment, along with the bolt on the other side that allows for vertical movement.
NOTHING.
I need to figure out how to get the power steering pump to move as I need to replace the belt and reduce the slack that will keep the new belt from slipping....
Maybe I need to post some pix of where I currently am?
Old Dec 2, 2012 | 12:37 AM
anomolee's Avatar
yes, post some pics. If I can't remember what I did I'm sure someone here will help you out.
Old Dec 2, 2012 | 12:38 AM
Engine: LB9 | LS1
Thanks... will post pix in a few.
Old Dec 2, 2012 | 12:55 AM
Engine: LB9 | LS1
Some pix
Attached Thumbnails Trying to remove water pump cant remove ps bracket-water_pump_1.jpg   Trying to remove water pump cant remove ps bracket-water_pump_2.jpg   Trying to remove water pump cant remove ps bracket-water_pump_3.jpg
Old Dec 2, 2012 | 12:56 AM
Engine: LB9 | LS1
one more...
Attached Thumbnails Trying to remove water pump cant remove ps bracket-water_pump_4.jpg
Old Dec 2, 2012 | 04:58 AM
kauboy's Avatar
Car: 83 Z28 Crossfire
Originally Posted by IROCgiraffe
Some pix
One more bolt from the back of the steering pump below the bolt in pic # 3.
Old Dec 2, 2012 | 09:03 AM
TNT garage's Avatar
kauboy is correct. imagine my disspointment when my water pump lost its seal after only 200 miles on a rebuild.. good luck
Old Dec 2, 2012 | 01:53 PM
Engine: LB9 | LS1
got it.... Thanks guys!
Old Dec 2, 2012 | 07:30 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
that bracket setup is one of the most pointlessly convoluted things GM has ever done... a swap to the 68-75 setup really simplifies things.
Old Dec 2, 2012 | 07:45 PM
Engine: LB9 | LS1
TRUTH
Old Dec 30, 2012 | 07:06 AM
austleadfoot's Avatar
Car: 86 ta firebird
Axle/Gears: borg 277:1
any exploded view pics of how it goes back togeather?
Old Dec 30, 2012 | 02:19 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Or, a serpentine set up.
Old Dec 30, 2012 | 02:48 PM
kauboy's Avatar
https://www.thirdgen.org/forums/atta...manual-ps-pump
Old Dec 30, 2012 | 04:22 PM
Car: 86 ta firebird
awsome kauboy!!! thank you
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
