Champion Radiator Won't Fit
Old Dec 26, 2012 | 05:07 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
I Got My Radiator Back In October And Until Now I'm Installing It. It's The 3 Core Champion Radiator And The Top 2 Fins Are Too Tall For My Fan Shroud. Any Ideas? Fyi I Did Remove The Bottom And Top Rubber Supports
Old Dec 26, 2012 | 05:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Champion Radiator Won't Fit
Pull it back out and see if the core support is bent up.
I did one last year and it fit with the rubbers out top and bottom.
I had to shave the top ones a bit tho.
Old Dec 26, 2012 | 05:53 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
I'll pull it out again and see what I find. I Added another picture pointing at the top fins.
Old Dec 27, 2012 | 09:50 AM
kad5118's Avatar
Car: 91 gta ws6
Transmission: 700 R4 TRANS
i have seen those champion radiators i got one for my 80 montecarlo and i was looking into getting one for my 91 gta.which model do you have
Old Dec 27, 2012 | 10:44 AM
Twin_Turbo's Avatar
That's a common problem, you need to fabricate something yourself to make it fit. Would be even a bigger PITA if you retain the stock fans
Old Dec 27, 2012 | 10:54 AM
kad5118's Avatar
Car: 91 gta ws6
nice engine layout
Old Dec 27, 2012 | 02:02 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Since the 24th of this month was the last day to return it I guess im stuck with this radiator. I want to retain the stock fans cause I dont have enough cash to buy new ones.
Old Dec 27, 2012 | 08:00 PM
one92rs's Avatar
Car: SOLD!!!!!
from what i have read they are hit and miss. i didnt buy one due to the fins inside the rad being different. good luck.
Old Dec 28, 2012 | 10:49 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
I'm running the 3 core Champion with the stock fans and the stock cover on top.
Here's the deal: I had to cut the bottom rubber pieces down to near nothing. "Trimming" is an understatement. I had juuuuuust enough to barely cover the spiky points on the shelf below the radiator.
Upper rubber pieces are basically horizontal only. The half moon shape is long gone. If I were to do it again, I probably wouldn't use the top rubber pieces at all.
I had to push down on the cover and pull backwards in a "tug of war" position to get the cover to align itself with the bolt holes as well as hold down low enough. I had a friend put the bolts back in. It's flush on top. But I dread having to undo it in the future.
So yes, the stock radiator cover piece will fit. But it's not easy. I don't know how one would be able to do it by themselves.
Old Dec 31, 2012 | 03:21 AM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Thanks guys for your help. I manage to get champion to exhange my radiator for a 2 row instead (dont plan on doing 450 hp anytime soon). I removed both top and bottom rubber pieces and it still didnt bolt up, no structural damage either. I guess ill just invest in a stage 2 water pump and more redline water wetter
Old Jan 1, 2013 | 12:43 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I cut the top of the support a little. two fan setup.
My bigger problem was the upper hose was in the way of my supercharger pulley. Maybe 20 minutes with the air body saw.
-- Joe
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
slade5612
Aug 11, 2015 07:19 PM
