low temp fan switch
Old Mar 10, 2010 | 01:09 AM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
low temp fan switch
so the other day i got a low temp fanswitch
hypertech brand and for some reason it didnt fit instead of my old one
and i compared between both of them and it seems that the hypertech switch has a bigger tread then the stock one
i saw that jet also makes these but i dont want to ordere it and the hastle of draining the coolant from the block
any ideas??...has anyone ran into the same problem?
i have 88 iroc z with the 305 tpi
Old Mar 10, 2010 | 01:16 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: low temp fan switch
you sure you pulled the correct one off? ...
Old Mar 10, 2010 | 01:44 AM
88I-ROC's Avatar
Axle/Gears: 3.08
im pritty sure its located on the passenger side of the block and the connection fitted just fine but the switch itself didnt fit the block....wierd
Old Mar 10, 2010 | 03:52 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
there are 2 switches there on the passenger side make sure you have the right one not the knock sensor
Old Mar 10, 2010 | 11:24 AM
88I-ROC's Avatar
Axle/Gears: 3.08
im pritty sure it was the correct one....i dont belive that if u pulled the knock sensor collant will start gushing on u...beside it looked very similar to the aftermarket one
Old Mar 10, 2010 | 11:28 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
You sure you have the 305? double check the part number, also you might want to go to your local auto parts store and compare one of theirs with the one you bought and see if they're the same or are different, possibility that this engine may not be what you thought you had... ... at the auto parts store they can then perhaps help you narrow a specific year that your car will happily accept...
Old Mar 10, 2010 | 11:33 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
http://www.summitracing.com/search/P...ord=fan+switch
which one of those did you purchase? click on the number you purchased and then go to application and make sure you're on it...
Old Mar 10, 2010 | 11:52 AM
88I-ROC's Avatar
Axle/Gears: 3.08
first of all...this is my 4th 3rd gen camaro that i owned so im pritty sure i know the make and model to my car not to mention the engine type...and i know this is the original engine cause i bought it from the guy that actually got the cae from the dealer back in 88...cant go wrong with that
also i know its the 305 because the 350 didnt came with the 5 speed and mine is a 5 speed
second....i actually got the switch from the auto parts store and the part number matched the part number online as well....so i dont know whats going on
i might try the jet kind fan switch and hopefully its gonna fit
Old Mar 10, 2010 | 11:58 AM
KNBlazer's Avatar
Engine: 5.1 4bbl
well then ... go back to the auto parts store and tell them to pull another switch, cuz the one they gave you apparently is packaged wrong... double check with an OEM version...
Old Mar 10, 2010 | 12:05 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Is this what you got? You probably just got wrong packaging that's all...
Old Mar 10, 2010 | 12:23 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
I just replaced mine recently... I was given to understand that it was the HIGH temp switch... in Pass cyl head between 6 & 8
Old Mar 10, 2010 | 12:47 PM
daveb123's Avatar
Car: 82 Z28
Transmission: BW T-10
I used to buy the cool fan switch from GM. The part # is 3053190, discontinued now, but Collectors Auto Supply has them,
(250)767-1974
Old Mar 10, 2010 | 07:17 PM
88I-ROC's Avatar
Axle/Gears: 3.08
the switch in the pic is very similar to the one that i got except i didnt got the wire and the adapter...just the switch itself
i actually returned that switch and got my money back
i think im gonna try the jet switch from a diffrent parts store
hopfully it will fit good
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
krisner89
Oct 10, 2015 06:03 AM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
