a/c compressor not clicking
Car: 91 Camaro RS
My ac compressor doesnt click when I turn the ac on. When I pull the plugs from the compressor nothing happens. The ac/heat fuse under the dash is ok and the heat works fine. When I unplug the relay by the acumulator the system shuts off same if I unplug the pressure switch. I also put a new screen in the orifice tube today. Please help it is getting warm down here and I have 2 kids. Car is a 91 RS camaro 305 auto just bought 2 days ago.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Cricket Took A Vacation
You need to find out if the system contains refrigerant, and at the proper amount.
Go to an auto parts store and get a set of gages, then with engine off (because the compressor won’t run anyway) measure the LOW side and see what the pressure is.
Happy Racing!
Happy Racing!
How bout those too scared to drive without headlights in the daytime
and the ones that need headlights for a little rain
2012sergen11
Oct 13, 2015 07:38 PM
Linson
Oct 1, 2015 09:50 PM
