heater core - leak on drivers side?
Old Apr 8, 2010 | 03:49 PM
Checkerbelly's Avatar
Hey guys. I recently noticed some coolant on the driver's side floormat of my 85 z28. Its coming in from just right of my right foot, somewhere above my foot. I reach up there and I don't feel anything but wires.
I read that most heater core leaks show up on the passenger side floor. Could mine be something different? A problem with the heater hoses maybe? Something else?
I plan to pick up a new heater core and attack from the passenger side. But if I don't feel anything wetness there I guess I'll start ripping apart the driver's side.
Any input would be appreciated. Thanks.
Old Apr 9, 2010 | 12:39 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: heater core - leak on drivers side?
Sounds like the leak is small, in the heater core, but has managed to get into the ventalation duct work. If the leak is up high in the core near the air outlet, it will travel as a mist thru the low foot ducts, condensing as it travels then dripping out.
Old Apr 9, 2010 | 02:28 PM
Good thinkin. Thanks.
I'm going to tear things apart this weekend and check it out. One thing I noticed is that the rubber over the firewall feels a bit like a waterbed when I poke it. I'm praying that thing isn't holding a bunch of coolant behind it.
Old Apr 9, 2010 | 05:14 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Are you sure its coolant/antifreeze thats leaking?
If so:
Just take off the right side underdash hush panel (cover) and then take off the
piece of heater/ac ductwork and expose your heater core and have
a look see if its leaking.
Old Apr 9, 2010 | 05:15 PM
THEGunboundGod's Avatar
Car: 1986 Z28
Axle/Gears: 4.11
Make sure you buy this one: http://cgi.ebay.com/ebaymotors/1988-...Q5fAccessories I just dealth with replacing my heater core and it was a nightmare. I bought one from sanels, and it didn't fit right. Bought another aluminum one off the internet, still not the right fit. Go with the copper one if you want the exact fit, even though all the aluminum ones say they'll fit, they won't.
Old Apr 9, 2010 | 05:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Maybe some help down the road:
https://www.thirdgen.org/forums/tech...e-82-86-a.html
JamesC
Old Apr 12, 2010 | 08:21 AM
Thanks for the info guys. Before checking back with this thread I went and changed it this weekend. I happened to buy a copper one from Advance Auto that fit pretty well.
It was my old heater core leaking. I checked the passenger side and there was a pond under the floor mat. So I got that swapped out with new hoses and things are back to normal. Except for slimey carpet.
I'd say it took me a good 3 hours or more.
Old Apr 12, 2010 | 08:26 AM
I should say, I think dirtywhite was right about the coolant traveling through the ductwork to get to the driver's side.
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
