bypassing heater core
Old Apr 11, 2010 | 12:26 AM
mannix91rs's Avatar
i have a 91 rs. can i just bypass the heat system altogether by running a single hose from the outlet at the back of my motor by the distributor to the inlet by the radiator cap?
Old Apr 11, 2010 | 04:03 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Re: bypassing heater core
Ive bypassed mine until I have time to install my new heater core but mine is a tpi so mine went from the front at the tpi direct to the rad.
Wht size of motor do you have .
Old Apr 11, 2010 | 06:19 PM
mannix91rs's Avatar
its a 305. tbi. i looked at all the hoses and which way the coolant ran thru them and i think it should be ok.
Old Apr 11, 2010 | 08:18 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Yes you can, the outlet on the intake is 5/8 and the inlet on the radiator is 3/4 so you will need an adapter some where in between.
$750 L98
Feb 1, 2025 02:25 PM
ndndndnd
Sep 28, 2015 08:00 AM
