Dual fans not working at all...
Old May 8, 2010 | 02:30 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am trying to figure out why my fans aren't working. I realize that one is controlled by the ECM and one is a temp switch controlled fan. I have tried the paperclip trick on the OBD connector and I get my code 12, but no fans. Where should I start? Is there an actual fuse for both fans somewhere? How about the relay(s) location?
Any help would be great!
[edit] As soon as I posted this, I went back out and checked the car - I traced the wiring back on the connector and found the ground was not bolted into the car. As soon as I connected it, I tried the paperclip trick again and the primary fan worked. Should both fans kick on with the pins on the OBD connector jumped?
Any info would be great!
Old May 9, 2010 | 12:24 PM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
Re: Dual fans not working at all...
When you trick on the obd (and when you use the scanner too) only the ECM's cooling fan starts.. so it is on my 88 iroc 350 TPI.
If you ground the secondary cooling fan relay, the secondary cooling fan starts and the ECM will start the primary fan too (in my car this happens with the engine runnig only and under 35mph).
I hope this helps
Old May 9, 2010 | 08:57 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
See my sig.
Old May 10, 2010 | 06:06 AM
asfalto's Avatar
Originally Posted by Reid Fleming
See my sig.
very important files!!
thank you!!!!!!!!!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Dquickshift
Aug 12, 2015 06:21 PM
Leggman1
Aug 6, 2015 04:15 AM
