heater outlet on radiator
Old May 16, 2010 | 03:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my radiator has the outlet for the heater hose, its a 3/4" od piece of aluminum tubing. Its not used, and since new has been capped with rubbed caps, clamped on. I have had to change the cap 3 time over the years because they start to crack and leak.
Happened again today, good thing i ounly took a short drive and it didnt completely blow off, would have made a real mess.
anyway, aside from pulling the radiator and having the hole welded up, are there any better ways to plug/cap this opening?
Old May 16, 2010 | 04:17 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Re: heater outlet on radiator
You can get a brass plug of the corresponding pipe thread, usually 1/2" I think, dab a little pipe dope on there and call it a day.
Old May 16, 2010 | 04:18 PM
norcalz28's Avatar
http://www.summitracing.com/parts/PRS-1022/?rtype=10
Old May 16, 2010 | 05:33 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
um, no its not that simple
its just a piece of tube stickout of the radiator, with a rubber cap on it, its not a threaded connection, nor is the tubing thick enough to try to thread. Its made so you can slide a piece of hearer hose over it and clamp it on. essentially a barbed connection
Old May 16, 2010 | 05:36 PM
norcalz28's Avatar
then get the right radiator for your application, or put another plug on there for the next couple years. Seems simple enough
Old May 16, 2010 | 05:42 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
kind of a smart *** remark huh?
it IS the right radiator, they all have that connection, but i think the newer ones can be had with a threaded connection and a real threaded cap. Not plunking down $200+ on another radiator because of this.
maybe read my post, i have been changing the plug over the years and its getting to be a PITA. Looking for a different solution if there is one, hence the post
this one, note the rubber cap by the radiator cap
http://www.jegs.com/i/JEGS/555/51904/10002/-1
Old May 16, 2010 | 05:55 PM
norcalz28's Avatar
It's not rocket science dude, smart *** post gets a smart *** remark. Tried to help ya, I'm not the one leakin' coolant.
Old May 16, 2010 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
are you for real? the hell is wrong with you? i make a simple post, looking for a ALTERNATIVE to the rubber cap, if there is one, and you come in with an attitude? Its not rocket science, its a simple question, which needs a simple answer, like "no", or "your beat, gotta weld it", or "yeah this "x" will work..."
Old May 16, 2010 | 07:38 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
You can do the brass plug and epoxy it in the radiator tube. As long as you dont leave a pinhole it should hold fine.
Old May 16, 2010 | 07:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i was wondering about using epoxy of some kind, i guess it could work as long as it can hold the pressure and with the expansion/contracting of the aluminum and not come shooting out.
Old May 16, 2010 | 07:46 PM
travis401's Avatar
Car: 91 Camaro RS
2 part epoxy is some pretty strong stuff. It should hold up fine.
Old May 16, 2010 | 08:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you considered trying a bolt plug ?
I believe you can get them all the way down to 1/4".
Old May 17, 2010 | 12:11 AM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Would you/have you considered taking your rad to a shop to have a cap(Alum) welded on? It would make your rad bullet proof!
Old May 17, 2010 | 12:19 AM
Car: 87 T-Top GTA
I wonder, does epoxy allow any flex, or does it harden up like a rock? If not, I would think it WOULD crack over time with expansion/contracting.
Old May 17, 2010 | 12:29 AM
travis401's Avatar
Car: 91 Camaro RS
Thats a good question. All the epoxies Ive used are rock hard when cured. Maybe they make some that flex?
Old May 17, 2010 | 06:46 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
could cut a piece of heater hose off then get a brass plug to fit into the hose and 2 clamps and done not sure if your wanting a clean look or not but that'll work done it a couple times before on cars
Old May 17, 2010 | 06:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
yes, thats the ultimate solution, but i dont want to tear the radiator and everything out right now, i will sooner or later for other reasons, for now i just need a better temporary fix
Old May 17, 2010 | 06:08 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats the other fix, and would last longer than these crappy plugs that i just bought more of, but i need it to look decent, and unfortunatly thats just not it.
Old May 17, 2010 | 06:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
im sure it would eventually fail. OE radiators are epoxies together and they are fine, but the epoxy is not used in a 3/4" think blob either.
Old May 17, 2010 | 07:28 PM
tom86iroc's Avatar
Car: 1986 iroc
86 figured you were looking for neatness we do that to customers cars that arent looking for neatness lol some people don't care good luck on fixing that
Old May 17, 2010 | 09:15 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Have you tried browsing the plumbing and irrigation aisles at hardware stores? There are caps for a variety of piping systems.
Here's a "flexible" pvc cap with a clamp. It's similar to what you've been using, but these are for heavy-duty applications. They can be used as permanent caps on piping under pressure, so it shouldn't blow apart like that cheap rubber cap does. Unfortunately, the sizes online are too big, but maybe there are smaller sizes in the store.
http://www.homedepot.com/Building-Ma...atalogId=10053
Or here's a 3/4" cap for pvc pipe used for irrigation systems.
If you've never assembled a pvc sprinkler system, the pieces are "solvent welded" together. I don't know how snuggly that cap will fit over the nipple in the radiator, but if it's a tight fit(the tighter, the better), then slather the outside of the nipple with the weld product(glue, similar to one-part epoxy), then slide the cap over it. Then hit the cap with some flat black paint(or paint it first).
This holds-up to the extreme pressures of sprinkler and plumbing systems, so it would withstand the pressure of a coolant system. But there's no going back... once you slide that cap on, the only way to get it off would be to cut-off the nipple, itself, because that weld product melts the parts together, so the cap and the pipe would, literally, become 'one.'
Or cutting-off the nipple is another idea, cutting it as flush to the radiator as possible, maybe even sanding down the leftover edge after you cut it off. Then it seems like you should be able to find some kind of petcock/draincock, valve, etc., to "bolt" through the hole to close it off. This would probably be the cleanest-looking way to go, if such a fitting exists.
So checkout a hardware store, a large one, or even a "mom-and-pop" store; it might be worth the trip. Seeing all the different parts in person might help you configure something in your mind that would work.
Old May 21, 2010 | 09:52 PM
checkeye's Avatar
try the heater hose with a chrome nipple and cap. Should be almost pretty and will last a long time.
Cut a short piece of heater hose, insert the pipe nipple inside. Cap the end of the nipple. Secure with two hose clamps.
3/8 " nipple will be 5/8" O.D, buy some rubber high voltage electrical tape, wrap the nipple to achieve the 3/4" of the heater hose I.D.
A 1/2" nipple would be 7/8" O.D. , maybe the heater hose will stretch ...
Either way you would have a few inches of heater hose with a chrome cap on the end.
PVC or fernco caps are not made for the temp of coolant.
Old May 22, 2010 | 10:25 AM
checkeye's Avatar
I just looked at my radiator this morning. That nipple has threads on the inside and a plastic plug with an o-ring is used to seal the tube.
Check if your's is threaded inside, maybe that plug is a dealer item.
Old May 22, 2010 | 01:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
its not a factory radiator, i posted a link further up the page
for now i just popped another crappy rubber cap on it.
buuuut, i did pickup a slightly larger ID cap, so the ridge on the tube off the radiator does not stretch the cap as badly. maybe this will keep that spot from cracking
sheachopper
Jul 31, 2019 11:27 AM
bplessy
Sep 30, 2015 12:14 PM
