tranny cooler lines touching header
Old May 20, 2010 | 08:55 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
so i was under my car again messing with the headers, and i noticed that
the two metal cooling lines are touching my header and im not sure if that is normal or not. They wont move from that position either and im afraid of bending them incase i break them.
so should they be there or not?
Old May 20, 2010 | 09:04 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: tranny cooler lines touching header
No, they should be up against the block. You can tweak them alot before they kink/bend. Just move them enough to get away from touching the header. suprised you dont hear a rattle from under the car.
Old May 20, 2010 | 09:11 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
man, mine are like 4-5 inches away from the block, im going to have to see what i can do with it tomarrow.
Ive never heard a rattle from them though.
Old May 20, 2010 | 10:52 PM
Engine: Vortec 357
you should have clips that secure them against the block. If you dont I may have the ones from my stock motor still.
Old May 21, 2010 | 07:54 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
if you cant move them away to far and afraid of breaking them put a wrap on them to atleast cool the lines alittle you should be able to moive them alot if they're not corroding
Old May 25, 2010 | 12:41 AM
jay173's Avatar
Easy fix would be to use zip ties and you can cut them off at any time and there cheap.
Old May 25, 2010 | 03:20 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Thanks for the advice
i was able to bend them enough so that they arnt touchingthe header anymore.
Reddeath210
Oct 6, 2015 08:20 AM
spaigo
Aug 21, 2015 07:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
