Temp. gauge doesn't work.
Old May 23, 2010 | 12:13 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Does anyone know why my temp. gauge won't work? Sometimes when I turn on my heater it will peg all the way to the top and stay there for a couple days. But most of the time it won't move one bit from the bottom of the gauge. I've replaced my temp. sensor, fan switch, and thermostat. Where do I go from there?
Old May 23, 2010 | 04:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Temp. gauge doesn't work.
The gauge itself might be bad. Have you traced the wires from the temp sensor on the manifold to make sure its not shorted out or cut or fryed in some way? The fan switch and thermostat dont have anything to do with the gauge. Its run off its own sensor on the front of the manifold and the wires run straight into the car and in to the dash harness to the gauge cluster.
Old May 24, 2010 | 08:49 PM
Engine: 350 S/B
I've traced the wire to the drivers side manifold and it looks/feels ok. Is there anywhere to get an O.E.M. replacement gauge?
Old May 24, 2010 | 08:54 PM
travis401's Avatar
Car: 91 Camaro RS
I think hawks third gen has a few stock gauges. Or you can hit up a local junkyard.
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
dyeager535
Aug 28, 2015 08:10 AM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
