concerns about my a/c compressor..help
Old May 23, 2010 | 08:49 PM
RICHRAD's Avatar
my a/c has been very low on refrigerant (probably out).. i added a few cans tonight.. the first can got the clutch cycling, then the second can kept the a/c cycling full time and blowing cold.. What i have concerns about is that my compressor has ticking/rattling noises when engaged, the belt shakes as if its loose(but its tight), and the compressor and one line gets too hot to the touch..i just shut it off.. was i supposed the add a conditioner or oil to the charge? did I do damage? ..its a 86 Trans am, v-belt system
Old May 23, 2010 | 08:53 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: concerns about my a/c compressor..help
a few questions. did you vacuum the system? was the system converted to r134a? sounds like the compressor may be about to let go. but a hot high side line is normal.
Old May 23, 2010 | 08:57 PM
RICHRAD's Avatar
It has the converted fittings, but i didn't think of the system needing a vacuum. Not only is a line hot, but the compressor is very hot. Will a clutch problem heat up the compressor? .will an oil charge help?
Old May 23, 2010 | 09:07 PM
what was the system pressure before charging? if it has a full charge now it may be too late to add oil but you can try. when the compressor does lock, make sure you at least replace the accumulator and orifice tube, add 2oz of the correct pag oil when you replace the compressor. if you get a salvage yard compressor make sure the pulley and clutch spin with the right drag and replace the oil in the compressor and pull a good vacuum.i like to flush the entire system with ac flush.
Old May 23, 2010 | 09:44 PM
RICHRAD's Avatar
I did not have gauges, just recklessly added refrigerant I guess.. I 've done this years back with no problems.. Will get an oiler charge can tomorrow and see if that calms things down. What concerns me most is the erratic belt shaking and easily heated compressor..
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Mdenz3
Sep 17, 2015 08:36 AM
