need some help..on fan switch and thermostat
Old Jun 7, 2010 | 09:54 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
im trying to pinpoint a surging issue and my car running like crap...
I found that the end of my fan switch on the passenger head is broken but still connected.....i dont know if that would cause a surging issue at idle and not running right once the car is warmed up...after doing some searching and reading i found that it could be my coolant sensor also.
SO? i cant remember what fan switch i had and thermo......i think it was on at 176 and off at 166 with a 160* thermostat....
also im thinking just a standard coolant sensor? 3/8 npt?
help me out
what do you guys recommend for my 383
thanks
Old Jun 8, 2010 | 03:37 PM
Re: need some help..on fan switch and thermostat
come on guys!
Old Jun 9, 2010 | 12:08 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
If your computer isnt seeing the engine get warm enough, it wont go into closed loop mode. Most FI systems want about 180-190 degree operating temp. The faster you get to the temp and stay there, the better. Turning the fans on too soon, with an early opening tstat will take longer to get to operating temp. Running too cool can actually be a bad thing.....
Old Jun 17, 2010 | 09:54 AM
RedDevilSS13's Avatar
I'm experiencing the same issue. My fan switch wire is broken off as well. I replaced the coolant temp sensor on the intake manifold, and it still acts up.
Also, my coolant fans stopped working. Do you have the same issue?
I have a new fan switch wire/connector from tpiparts.net on the way; I'll let you know if it works.
Old Jun 17, 2010 | 10:27 AM
mine is not completely broken off....it can still be connected but not a good connection...know what i mean?
nah,,,,, my cooling fans still work..
yeah let me know what happens when you get you fan switch right and see if that fixes your problem.
Old Jun 17, 2010 | 04:34 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If you think that your ECM is not going into closed loop because you suspect the CTS or it's connector is bad, simply jump the two sensor wires together when it runs like crap and see if anything changes. Shorting the CTS sensor leads will confuse the ECM into thinking the motor is full hot.
It is, however, unlikely that this is the cause of your problem. Surging is generally caused by a lean condition. In Open Loop your ECM should be running richer than in Closed Loop. I wouldn't expect your motor to run crappy in Open Loop unless it's also running crappy in Closed Loop. Which kinda fits your "not running right once the car is warmed up".
Bubbajones_ya
Jul 6, 2024 08:32 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
scotrans am
Sep 5, 2015 04:26 AM
85Special
Sep 3, 2015 04:21 PM
