running water in radiator?
Old Jun 8, 2010 | 11:12 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im currently trying to get my car up and running again and i was just wondering if i could run water through my radiator until i know i have it running then i could dump it and get some anti freeze.
so is this safe?
Old Jun 8, 2010 | 11:15 AM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Re: running water in radiator?
As long as you don't think your going to incur any freezing temperatures while there is water in it, you'll be fine. Most drag strips require anti-freeze replaced by water while cars are running on them, to prevent anti-freeze spills.
Old Jun 8, 2010 | 11:34 AM
Engine: L31 350
my biggest concern is the water rusting my radiator, its a new radiator and i dont want to replace it again
Old Jun 8, 2010 | 11:45 AM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Use distilled water. The mineral content would be nil.
Old Jun 8, 2010 | 11:48 AM
rich5's Avatar
Car: 91 camaro RS
Just watch the TEMP, water heats up alot faster, as far as rust goes just pul the radiator hose off and let all drain engine to. it will dry. I just put some stop leak in for my head gasket in a explorer but you had to drain the antifreze and replace with water and run it then let it sit for about two days. all in all every think worked fine, no rust .
Old Jun 8, 2010 | 01:15 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Actually water cools better than water/antifreeze. Antifreeze is really more for corrosion protection and sub freezing levels than it is for cooling.
Old Jun 8, 2010 | 01:21 PM
Matt S iroc's Avatar
yeah water will boil faster then antifreeze,id suggest putting some in it after u get it running but for the most part ull b fine.i wouldnt worry to much about it.and yeah i would suggest u use distilled also.
Old Jun 8, 2010 | 01:54 PM
Engine: L31 350
right now i have tap water in o.o
Old Jun 8, 2010 | 02:18 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
You'll be fine.
Old Jun 8, 2010 | 03:45 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Engine: 350 5.7L Carb'd
Axle/Gears: Disc 2.77
i wouldnt leave it for a long long period of time, but should be fine until you get it running, unless of course its been 3 months down the line and still not running
Old Jun 9, 2010 | 12:04 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I ran my rad with straight water for a few weeks while working out minor bugs (most of which required pulling the rad or otherwise loosing coolant). No ill side effects now that I have a 15%/85% antifreeze/water mix, and even threw in a bottle of water wetter.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
