Water Pump Help
Old Jun 8, 2010 | 03:50 PM
gojayhawk1's Avatar
Car: 1986 Firebird
Engine: V8 5.0L
Transmission: stock 4 speed automatic
Water Pump Help
Hello everyone. I've been trying to replace the water pump on my 86 firebird 5.0L and am having trouble getting one of the bolts to fit on easily. My main problem is getting the bottom right bolt in because the PS bracket is in the way.
Do I need to remove the PS pump/bracket so I can easily attach it or is there another way to get to it??
I've tried fixing it once already(a couple days ago) and didn't get the gaskets on quite right so I figured I'd ask for advice before forging on again. I should use the silicon sealant on both sides of the gasket right?
Thanks.
Old Jun 8, 2010 | 05:44 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Water Pump Help
I was able to get all 4 bolts on my 89 Camaro 5.0L no problem. You shouldn't need silicon, I used Indian head sealant.
http://www.acehardwareoutlet.com/Pro...aspx?SKU=88220
Works great on a lot, you don't need to put a lot either, a light coat will do fine.
Old Jun 8, 2010 | 09:56 PM
gojayhawk1's Avatar
Car: 1986 Firebird
Engine: V8 5.0L
Re: Water Pump Help
Thanks, I got it to work this evening on my first try. I just attached the 3 bolts that were easily accessible first. That bottom right bolt was a pain to get but I was able to get a socket on it after a couple hand revolutions. It's a very tight fit, but much easier than removing the PS pump. Thanks for your help.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
