What Temp should the Fans kick in?
Old Jun 10, 2010 | 11:07 PM
Dany89's Avatar
I was wondering when should the fans kick in? It's a 87 GTA 5.7(350) it has the dual electric fans.
Old Jun 11, 2010 | 06:18 AM
asfalto's Avatar
Car: '88 camaro iroc-z
Transmission: TH 700 R4
Axle/Gears: 2.77 Borg Warner Axel
Re: What Temp should the Fans kick in?
is it a tpi?
the cpu fan (driver side) kicks in at 223 F
i don't remember the 2nd one ( maybe 238 F) but always too late.. i putted a manual switch on it!
ciao
Old Jun 11, 2010 | 03:50 PM
Dany89's Avatar
Thanxs man, yes its a TPI. both of my fans kick in at the same time at about 230F more/less. What should i do to get the running properly?
Old Jun 11, 2010 | 05:41 PM
asfalto's Avatar
if your fans run, there aren't relays problems.
i guess you have a bad wiring, or a bad temp sending unit, or a modified ecm temp.
so the primary fan doesn't start (223 F) and you have to wait till the secondary fan kicks in (stock 234 F).
i've got a 88 350 tpi and i confirm that the secondary fan swithes on the primary fan too (if it isn't alredy on).. tried myself grounding the secondary fan relay.
this is a thread of mine about this
https://www.thirdgen.org/forums/cool...ng-report.html
these are very useful (replais by reid fleming)
https://www.thirdgen.org/forums/cool...esnt-turn.html
https://www.thirdgen.org/forums/cool...-diagrams.html
....or maybe someone bridged the fans.. check the wires!
i hope this helps!
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Sep 16, 2015 12:37 AM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
