Should the dual fans turn on with ignition?
Old Jul 2, 2010 | 11:38 PM
ms87iroc's Avatar
Car: white 87 iroc-z
Engine: 5.7 tpi
Axle/Gears: 3:27
I have an 87 iroc 5.7 tpi and the dual fans turn on when you turn the ignition 1 click towards dash, is it supposed to do that? or are they to turn on when the engine gets hot only. please help
Old Jul 3, 2010 | 08:10 AM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Re: Should the dual fans turn on with ignition?
Like what Stephen said, that is what I did, wired the fans to power on when the engine is running. Works great
not to sound like a jerk, but like I remember years back being told, try the search function first if you have not yet. Repeat questions take up room on the server. Generally, if the wiring is normal, no faults and no one has modified your wiring, no the fans should not both turn on when you turn the ignition on.
Old Jul 3, 2010 | 06:54 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Somebody rewired your fans somehow, they're not designed to work that way stock. Here's some stuff about how its supposed to be https://www.thirdgen.org/electric_co..._spec_mod_dual Depending on your usage it might work OK for you for now. Depends on how well it was done. Worth finding out. Check out other posts on here on the same subject by using the search feature as resinlake suggested. Have Fun!
Old Jul 3, 2010 | 06:59 PM
Stephen's Avatar
Car: 87 GTA
If the engine is already hot to the point that the fans should be on? Then yes.
First thing in the morning, when an engine is cold? Then no. A former owner has rewired them to be on at all times. Nothing to worry about if so. I've done tat in the past on other cars, when they needed the extra cooling on hot days.
Old Jul 5, 2010 | 10:32 AM
ms87iroc's Avatar
Engine: 5.7 tpi
Axle/Gears: 3:27
Thanks guys for the info. I just joined a little while ago didnt know it was a faq. I thought that was the purpose of this site, to interact with other 3rdgens.
Old Jul 5, 2010 | 10:40 AM
Stephen's Avatar
Car: 87 GTA
Originally Posted by ms87iroc
....I thought that was the purpose of this site, to interact with other 3rdgens.
It is. Don't feel like anybody was trying to run you off. But once you've been here years 7 years & years &.......You'll begin to understand the frustration of having to answer the same questions over & over, when there is even a FAQ that answers that, and a search feature available for people to utilize & get their questions answered much faster than hoping somebody sees your question and answers it.
Welcome to TGO!
Old Jul 5, 2010 | 11:37 AM
ms87iroc's Avatar
Engine: 5.7 tpi
Axle/Gears: 3:27
I will try search next time. I did install a new fan relay switch and that did not help, so it must be wired to stay on. Since i am not driving this car in the winter and do not need the heater to run at maximum temperature, i should just leave it alone, it will not hurt but only help. Right
Old Jul 5, 2010 | 12:18 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Only drawbacks are shorter fan life and more power draw on the electrical system (meaning less gas mileage), but I would find out how they re-wired it so if it goes bad you can fix it or wire it back to stock.
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
Bryan F
Aug 18, 2015 02:28 PM
