No fan with no ignition and hot engine
Old Jul 3, 2010 | 09:43 AM
bminnix's Avatar
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
Ive been having trouble with the cooling fan. It works correctly with the ignition on. The fan will turn on when the engine gets hot enough. It will also run constant when the A/C is switched to on. Yet, when the ignition is turned off, isn't the fan supposed to stay on until the engine cools to the designated temperature?
If so, what could be causing this?
Old Jul 3, 2010 | 10:16 AM
Twin_Turbo's Avatar
Re: No fan with no ignition and hot engine
No, the relay is ignition switched, the fan turns off w/ the ignition. With the water pump not pumping there is little cooling thata running fan would do. It is true that afetr turning the engine off heat soaking will spike the coolant temperatuer. This is why serious race cars have a cool down unit attached via a quick disconnect.
Yours is working the way it should.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
