want to hook up the fans so they run automaticly
Old Jul 26, 2010 | 09:30 PM
camaro307's Avatar
i have the fan to a ignition source and when i shut the car off the car stays running and i know its from the fan wiring but i hate haveing a switch so my ? is how do i hook it up to the ignition and be able to shut the car off properly?
I have a 350 carb'd no computer
Old Jul 26, 2010 | 10:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: want to hook up the fans so they run automaticly
Get a seperate adjustable fan controller - they run anywhere from $35 on up into the $100+, just depends on what bells and whistles you want. Then you can adjust at what temp the fan comes on.
Old Jul 27, 2010 | 08:43 AM
Pocket's Avatar
Car: 91 Trans Am
Use the fan circuit from a TBI car
http://www.austinthirdgen.org/mkport...an_V8_vinE.jpg
It uses a thermal switch in the pass cyl head instead of being commanded by the ECM. IIRC Hypertech offers multiple thermal switches closing at different temperatures. It may be a different company though
To get this to run even when the car is off, switch the fused 12v IGN to fused 12v battery
eightsixseven
Dec 16, 2024 01:50 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
