CFI Water Outlet/thermostat Housing
Old Sep 3, 2010 | 07:00 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
I cannot find a crossfire injection water outlet/thermostat housing. Every one I found does not fit and the hose neck angle is way off.(napa, oehq, rock auto, and etc) it keeps hitting the a/c compressor. Does anyone have a CFI theromostat housing or know a suitable replacement?
Old Sep 4, 2010 | 12:49 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: CFI Water Outlet/thermostat Housing
LOL...I had that problem too-back when i first put in an
'84 vette engine in my z28,the vette housing was wrong
and the carb style one had the hose against the A/C
bracket...Found one from a '78 monza with the 151
"iron duke"that worked well after i notched the bolt
holes.Later found a proper C/F one
will check to see if i have a spare..
Old Sep 4, 2010 | 04:33 AM
KITT1983's Avatar
thanks please let me know what you find? do you have any part numbers?
I am planing on puting a 1984 corvette CFI 350 in my 1983 T/A sometime in the future. there is no susbstite for cubic inches
Old Sep 6, 2010 | 07:24 PM
KITT1983's Avatar
bump
Old Sep 7, 2010 | 07:15 AM
KITT1983's Avatar
bump
Old Sep 7, 2010 | 06:12 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
found a #on the one in my car;14037618-if that is a
good#possibly a GM dealer could find one...
meanwhile i will keep my eye out for one in my parts
stash
Old Sep 7, 2010 | 06:32 PM
KITT1983's Avatar
stash
thanks
that is the correct GM part number but is discontinued by GM
let me know what you find in your stash
Old Sep 7, 2010 | 11:42 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
did not find any...i could find the monza one iwas using
and send that if you could use it
That sux that GM discontinued that part number-
probably some still around if the dealer could do a
search...
Old Sep 9, 2010 | 11:31 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
i looked at a standard carb thermostat housing and it
looks like if the bolt holes were notched so that the
housing could be rotated clockwize on the manifold,
hose might just clear the A/C bracket-might need washers under the bolt heads
Old Sep 12, 2010 | 08:59 PM
KITT1983's Avatar
bump
Bubbajones_ya
Jul 6, 2024 08:32 PM
69GTOby
Apr 18, 2016 02:34 PM
jrdturbo
Mar 31, 2016 02:58 PM
customblackbird
Oct 1, 2015 04:30 PM
st.evel07
Sep 19, 2015 09:24 PM
