Stupid Question (Re: Electric Fan)...
Old Oct 22, 2010 | 09:02 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Can someone here please explain to me the function of the "fan relay"?
I am also wondering how you guys wire up an electric fan in a third-gen that was not originally equipped with one...
Old Oct 22, 2010 | 09:16 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
Re: Stupid Question (Re: Electric Fan)...
i just finished wireing up my dual fans i used the stock relays the ground off of the fan will go to a ground, the power off of the fan will go to termnial A of the relay, termnial D will go to a switched power or G8 of the c100 connector, termnial E will go to the battery or constant power, termnial F will go to your ecm witch is the switched ground or to the thermostat
Old Oct 23, 2010 | 01:30 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
A relay is a switching device that handles heavier currents than smaller switches can handle. When the small switch attached to the relay is flipped it lets current flow through an electromagnet inside the relay. The magnet pulls the heavy duty contacts together to power whatever device it's attached to. Anything that draws a large current (fan, headlight etc.) normally uses a relay. If your car never had an electric fan you'll need a fan, a relay and a thermostatic switch. Maybe all in one kit? The thermo switch may be inserted into the top heater hose and will activate the relay which will turn on the fan at the set temperature.
Old Oct 23, 2010 | 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Or two. Here's what I did:
https://www.thirdgen.org/forums/cool...electrics.html
JamesC
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
