Water pump question
Old Oct 25, 2010 | 10:06 PM
shadow315's Avatar
Car: 92 Firebird
Water pump question
I picked up a motor, a 5.7L from a '87 Firebird w/ TPI.
It is going into a '92 which is carbed..
While it was out I was planning on putting on a new water pump. They're $32 at Autozone:
http://www.autozone.com/autozone/par...7_117067_6245_
Is that reverse rotation pump the right one & a good idea?
Thanks!
Old Oct 25, 2010 | 10:19 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Water pump question
I'd spend a little extra and get a quality water pump-
GM,edelbrock,stewart or other U.S.made
For $32,that duralast pump is probably chinese junk
that will leave you beside the road with your hood up
Rebuilts often have hub runout,so i don't care for those
either.
Old Oct 25, 2010 | 11:16 PM
shadow315's Avatar
Car: 92 Firebird
How about this GMB North America?:
http://www.summitracing.com/parts/GMB-130-1620/
Old Oct 25, 2010 | 11:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
GM or Stewart... the Edelbrock pump isn't anything special.
Reverse rotation if you have serpentine belts, standard rotation if you have V belts.
Old Oct 27, 2010 | 03:05 PM
shadow315's Avatar
Car: 92 Firebird
After owning 7 of these cars I can't believe I'm asking this but where the heck do you find a genuine GM part? The dealership?
Old Oct 27, 2010 | 03:49 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i may be a bit biased (having worked at a few parts stores past & present, you're welcome to take my opinion with a huge grain of salt), but i've never seen any of the brand new, lifetime warranty sbc pumps fail regardless of its country of origin. The remans, definitely, but on a stock application the sbc water pump's pretty much figured out.
Old Oct 27, 2010 | 04:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any store that carries Delco parts.
Old Oct 27, 2010 | 05:09 PM
shadow315's Avatar
Car: 92 Firebird
Cool, thanks everyone..
I ended up coming up w/ 1 more question- Looks like some pumps come w/ an outlet to the A/C.. Guess I should decide if I am going to run A/C or not before buying- is this correct?
Old Oct 27, 2010 | 05:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can plug the heater connection if your hose routing isn't going to use it.
Old Oct 28, 2010 | 11:07 PM
shadow315's Avatar
Car: 92 Firebird
I went to ACDelco.com and looked up the part. For the '87 5.7L they used p/n 252-595. I looked on eBay and found a NEW 252-595 for $29! It is on the way. There are different p/ns for the 88> cars- not sure what the difference is. I think I'm going to paint it blue.
Old Oct 28, 2010 | 11:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
'88 up is a counterclockwise rotation pump meant for
serpentine belt setups and does not have an accesory
bracket tab. '87 cars use the standard clockwise rotation
pump found on most 1976-'87 small block chevys.
Besides the different rotation,the hub bolt circle is
different so the"wrong"pulleys will not bolt on without
modifications-as long as you use '87-earlier belt system
that pump will work fine.
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
