HEAT! It's FREEZING OUTSIDE!
Old Nov 1, 2010 | 08:59 PM
Rauch's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: TPI 350
Sorry for the caps in the title, it's just getting to that time of the year where heat is mandatory.
Just bought my T/A last month and it turns out the heater core is not hooked up. Not having the RPO Codes for my car makes it a bit more difficult, but I'm still on the hunt to get it working.
Currently, my upper radiator hose is hooked directly to the top Tuned Port valve. The heated core is completely bypassed.
Judging by the parts list below, I would need to use a heater bypass valve, or not use it depending on the stock RPO's. The only other problem is not having the heater outlet pipe, and not being able to obtain one. Is this pipe necessary? It seems as though it'd just more convenient due to the hose not being as pliable as a pre-bent tube. Perhaps the smaller size prevents the heater core from too much pressure?
Old Nov 1, 2010 | 09:31 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: HEAT! It's FREEZING OUTSIDE!
The reason it's probably bypassed is because it's no good. I'd say you probably need to replace your heater core. You'll know because as soon as you hook it up it'll leak all over the carpet by where the passengers feet go. You don't need that heater valve. Just run one line into the heater core and another line out of it. I had one line coming out of my radiator into the heater core and the other came from the side of the throttle body.
Old Nov 1, 2010 | 09:42 PM
Rauch's Avatar
Engine: TPI 350
Yeah, I figured that was a possibility. But I thought for the best and figured when they dropped the new engine in they didn't hook it up, or removed it when they removed the A/C.
As for the metal pipes, are the necessary, or can I just use a few fittings to make it bend properly into place?
Old Nov 1, 2010 | 11:57 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Not sure if they're absolutely necessary but I'd try and fine one. The hoses would be damn close the exhaust manifolds and could possibly melt. If you went to a junkyard they'd probably have. Every third gen at a yard around here seems to have it.
Old Nov 2, 2010 | 02:07 AM
Rauch's Avatar
Engine: TPI 350
Well, let's hope my local one has a few sitting around . Whoever swapped this engine did a REAL shoddy job. Heat isn't hooked up, Oil Cooler isn't hooked up, and hell I actually think the tranny cooler isn't hooked up :|.
Old Nov 2, 2010 | 02:31 AM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
Im pretty sure that only cars with ac came with that valve. My understanding is that it redirects coolant flow away from the heater core when ac is on to increase effectiveness.
Old Nov 2, 2010 | 03:44 PM
Car: 1986 Trans am
Engine: 5.3 LM7
My 86 didn't have one and it had AC and all. Car was 100% stock when I bought it as well and I am only the 3rd owner so I doubt it was tampered with. Sure looked all original at least. Maybe it was available on the later models?
I'd still bet that your heater core is shot. How much harder would it have been to attach the lines to the core than just attach them together? Before you hook it all up, run a garden hose into one end and a drainage hose into the other and run water through it for a minute or so. Then check the floor for drips. Water will be much easier to get off your carpet than antifreeze, and the smell sucks. I replaced my carpet after my heater core went!
Old Nov 2, 2010 | 05:29 PM
Drew's Avatar
Before 1987 the heater bypass valve didn't exist on third gens... However on 87 up Camaros and Firebirds, with A/C the valve is used to bypass the flow of hot water away from the heater core to increase the A/C efficiency.
The difference between the two diagrams is A/C or not A/C.
If you're only worried about HEAT you don't need the bypass valve. Follow the diagram on the right and you'll have heat assuming your heater core isn't full of holes.
Old Dec 24, 2010 | 08:59 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
My original heater core broke(Sputum of anti-freeze was all over the passenger side) My dad bypassed it for me. He was original owner so i know it's all stock. Then i tried to remove the heater core myself but there's one damn screw that you need a special socket extension for. So,i brought it to the radiator repair. 8 hrs later he fixed it. I watched him do all of it. Just buy upper and lower heater hoses and run them to the firewall. Hopefully you wont have a pond on your passenger side. I know it's not the smartest way but its good to diagnose if the heater core is good or not.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
