single fan vs. dual fans?
Old Nov 7, 2010 | 06:54 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
My 1992 camaro 305 has one larger single fan on the radiator,and my uncle's 88 GTA has 2 smaller fans on his radiator. I searched this, but I didn't find any direct answers. Why the difference? He has the 5.7l V8. Is it because of the engine size? He also says that one fan may be for the AC, and the other for cooling the motor. Is that true? If so, why does mine only have one fan? We were talking about it today while we were working on my camaro, and I just thought I would ask.
Thanks!
Old Nov 7, 2010 | 07:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: single fan vs. dual fans?
Cars without A/C received a single fan, AFAIK.
Old Nov 7, 2010 | 07:35 PM
chevydrvr's Avatar
My camaro does have AC unless a previous owner added it. The owner I bought it from cut the lines though, but the AC compressor and everything is or was there.
Is there an rpo code for AC?
Old Nov 7, 2010 | 07:52 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
C60 is A/C I believe.
Old Nov 7, 2010 | 08:12 PM
chevydrvr's Avatar
Alright thanks, i'll need to check the codes next chance I get to the car.
Old Nov 7, 2010 | 09:07 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I think I read somewhere that TPI motors got dual fans. I know I pulled a set from an 89 IROC with a 305TPI...
Old Nov 8, 2010 | 12:28 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
A/C doesn't have anything to do with getting dual fans on our cars. It's like an option package thing. You've got an RS (base) with a 305 tbi, he's got a GTA (top of the line), with the most expensive engine you could get. You can switch over to dual fans if you'd like, but if your not having cooling problems and your keeping the car stock there really isn't a reason to.
Old Nov 8, 2010 | 05:30 AM
chevydrvr's Avatar
thanks nova! That does make sense. The only problem I am having is that the fan doesn't turn on when it needs to. The car will begin to overheat, then it cools back down again before it does. The previous owner said that you need to turn the ac on for the fan to turn on and cool the motor. I figured it's just the temp switch/sensor that needs to be replaced. I"m not even sure of my car came with ac. The compressor is there but the lines are cut and folded shut. I'll have to check the codes when I get a chance.
Thanks guys!
Old Nov 8, 2010 | 08:48 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, my 88 IROC has a single fan.
Old Nov 8, 2010 | 01:33 PM
Thanks guys!
If your car's got A/C equipment than it's probably stock, almost all thirdgen's came with A/C, and most people wouldn't add it if it didn't come with it. Turning the A/C on forces the fan to come on but you shouldn't need to do that. There is a cooling fan turn on switch that is located in the passenger side head. What temp does your fan turn on. GM has them turn on pretty late, I think it's like 235. You can get an aftermarket switch that turns the fan on earlier. Hypertech makes them and you can get em from summit.
Old Nov 8, 2010 | 03:45 PM
chevydrvr's Avatar
I think the switch itself is either going bad, or is gone. I'm not sure what temp it comes on, but the temp gets up pretty high before it drops again.
Old Nov 8, 2010 | 08:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If the switch was bad the temp would never go down as you said yours does. They normally go up around 220 before fan kicks in and it cools down. Lots of people find this too high for their own comfort, and as was mentioned earlier put in a fan switch that turns the fan on at a lower temp. In the summer around here it gets to be 110 degrees and the single fan still cools enough as long as the rest of the cooling system is good.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
scotrans am
Sep 5, 2015 04:26 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
