Fans won't come on
Old Nov 12, 2010 | 02:23 PM
KS91Z28's Avatar
Fans won't come on
I've done a few searches and found threads that started off with the same problem, but got off topic, or ended up with band-aid fixes.
I'm working on an '87 IROC 350 with dual fans.
Neither fan will turn on on it's own and the temp gauge is showing 240ish. Neither fan comes on when I turn the A/C on. I can make the secondary fan come on by jumping the relay, so I know the fuse is good and the fan works.
I've replaced the fan switch. I've pulled the fan switch wire off and grounded it with the key on and the primary fan comes on, so I know the fuse, relay, and fan are all good.
What next?
Old Nov 12, 2010 | 02:49 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: Fans won't come on
If your sure the relays are good, the next place to check is the control for the circuit. In your case the PCM, or the wire going to it.
Old Nov 12, 2010 | 04:56 PM
KS91Z28's Avatar
That might explain the secondary fan, but if I can disconnect the wire from the fan switch and ground it out to make the primary fan come on, what would that have to do with the ECM?
Old Nov 12, 2010 | 05:19 PM
KS91Z28's Avatar
As far as the secondary fan goes, how would I go about further diagnosing it?
Old Nov 15, 2010 | 12:18 PM
KS91Z28's Avatar
Anybody?
Old Nov 15, 2010 | 12:24 PM
Car: 87 Camaro
Engine: 305 LG4 (H)
Well, you said the secondary fan came on by jumping the relay, so obviously that fans relay is bad. For the ECM controlled fan, you said you grounded the wire and the fan came on. So, whatever commands the fan on when its plugged back into the circuit is malfunctioning, rather PCM or the wire going to it.
junior419
Apr 7, 2025 11:35 AM
Bubbajones_ya
Jul 6, 2024 08:32 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:37 AM
