still have coolant..
Old Nov 18, 2010 | 02:52 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I installed a knock sensor yesterday but when the old one came out only a couple of quarts of coolant came out... Doesn't it drain the whole thing or am I wrong?
Old Nov 19, 2010 | 12:45 PM
0pyders's Avatar
Re: still have coolant..
Originally Posted by tgoirocz
turn the hose on into the rad and itll back pump the block.
what hose are you talking about? connect it to the radiator?
Old Nov 19, 2010 | 01:37 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
If your goal is to drain the block, you'll need to remove the two block drain plugs. One on each side. Otherwise, just removing the knock sensor will only partially drain the block and some coolant from the head and intake coolant passages below the (closed when cold) t-stat.
Old Nov 19, 2010 | 01:40 PM
0pyders's Avatar
That's exactly what I needed to know, thanks so much.
Old Nov 19, 2010 | 01:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The knock sensor is the drain plug on that side.
Old Nov 19, 2010 | 02:16 PM
0pyders's Avatar
can I still just add coolant and be done with it though?
Old Nov 19, 2010 | 02:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sure
dixie wrecked
Nov 30, 2014 10:19 PM
Dr. Phil
Feb 5, 2011 08:59 PM
BladeX10
Aug 12, 2008 03:15 PM
peteh
Jun 21, 2006 10:04 AM
KiLLJ0Y
May 25, 2005 06:30 PM
