Correct Thermostat Temp Question???
Old Dec 26, 2010 | 11:10 PM
globalco's Avatar
I am putting together my rebuilt 92Z and want to know the correct temp for the thermostat. As I remember the original ran at 225 or so degrees and was a problem. Some people say 160 degrees is Ok and alot of people seem to follow that. I have also read that 160 degrees affects the operation of some engine functions and should be raised to 175 degrees. So what is the correct or best temperature??
My engine is a 355 with vortec heads a zz4 cam and close to stock compression.
Anyone got any good solid answers not based on opinion?
Thanks for your help.
Old Dec 27, 2010 | 12:17 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Correct Thermostat Temp Question???
195° thermostat was stock.
180° thermostat will do you just fine. I see no need for a 160°. Unless you consider 180° to be too hot. (I don't)
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
