Thermastat Leaking HELP!
Old Jan 18, 2011 | 08:53 PM
Kozusnik's Avatar
Car: 1986 Sport Coupe Camaro
Engine: V6 2.8L vin S 173ci - MFI GAS
Transmission: 5 Speed Manual
Ok day after Christmas heater core with out but I had been needing to change the thermostat for some time now... Changed it put new gaskets on i used two the first time and it was leaking still so went back and tried just using one with some therma gasket and surprise it still leaking.... If anyone can help please do...
Old Jan 19, 2011 | 11:18 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Thermastat Leaking HELP!
Did you get the right thermostat? Does it fit into the indention on the intake properly? You should always use gasketmaker with a thermostat, and I see no need in ever using but only one gasket. Did you clean out all the old gasket material before install with a razor blade? You should always have a clean dry surface when mating with gaskets.
Old Jan 19, 2011 | 11:39 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
make sure both mating surfaces are cleaned and free of any old rtv and gasket material. I always had good luck using one gasket with blue rtv on both sides. its a good idea to let the rtv cure a little bit before installing. be careful not to overtighten the thermostat housing bolts, could be causing the housing to deform and let out coolant
Old Jan 19, 2011 | 12:18 PM
Kozusnik's Avatar
Thanks for the replys No the store sold me the one for the 305 engine grr so much headache... Thanks both of you for getting back to me so fast I was pulling my hair out...
But Finally Problems Fixed!
Old Jan 19, 2011 | 02:33 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
For future T-stat replacements,
It also is a good idea to run the housing across a piece of sandpaper on top a flat surface.
I normally do it all the time and have no issuse afterwards but, the one time I did not do it, got leaks.
Old Jan 20, 2011 | 11:23 PM
Kozusnik's Avatar
Yeah I use a Flat head screw drive to get all the old gasket off and then go over with wire brush and it works great this time i blame the stupid auto store... Well it was my fault for not looking in the first place = / We all learn right?
Old Jan 20, 2011 | 11:33 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I wish places like CSK, Autozone, etc. were self serve because their ASE parts pros are freakin morons!
Old Jan 20, 2011 | 11:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The thermostats aren't the same?
Old Jan 20, 2011 | 11:42 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Originally Posted by Apeiron
305 and 350 thermostats are the same.
One of us is missing something because the OP has a 2.8 and if memory serves they are a small housing that a 305 or 350.
Old Jan 20, 2011 | 11:59 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
OE part numbers are different, but all the aftermarket ones I can find cross over between BBC, SBC and 2.8.
Old Jan 21, 2011 | 12:17 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
I noticed that aftermarket Mfgs will make one part and say it fits 3 different applications when really it does not work well for 2 (and at times 3) of them.
I just looked through some gasket I have laying around. Could not find any I know where purchased for a 2.8/3.1. I did have a Fel-Pro from a 4.3 kit and a couple of the oddball Tiawan ones. The Fel-Pro had a small center hole giving it more surface sealing area that the oddballs. And the oddballs have oval holes for the bolts to fit more applications than the Fel-pro one.
Old Feb 13, 2011 | 04:50 PM
Camaroboi's Avatar
Car: '84 Berlinetta, '86 Z28
Engine: 2bbc 2.8, MPTI 5.0
Transmission: 5spd manual, 4 spd auto
Amen to that bro, I had a major leak out of the weep hole on a brand new water pump and the guy looked at me and said "but it's new"
Old Feb 13, 2011 | 07:29 PM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
I've used the more expensive new types with the silicon gasket already inbedded, good stuff no leaks, reusable, no problems no extra sealant needed.
Old Feb 13, 2011 | 08:22 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
What kind are those??
Old Feb 13, 2011 | 09:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Fel-pro if you mean the thick blue ones with brown colored sealing ring. Works great
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
