Too Much Compressor Oil
Old Jan 21, 2011 | 08:28 PM
tyrant609's Avatar
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Hi Everyone,
Just bought a 87 T/A TPI and have a feeling the AC system is filled with too much oil. The system was empty so after leaks fixed i attempted to fill with R134a (It had previously been converted). The compressor cycles on and off very quickly and i am unable to put the correct amount of refrigerant into the system.
So the question is how do you remove oil from the AC system?
Old Jan 22, 2011 | 01:00 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Too Much Compressor Oil
You don't know it has too much oil. Did you add any? With the leak it is possible some oil got lost also. Did you replace any part or just some o-rings? If you replaced something like a compressor you should have drained the oil from that and put that much + back in the system.
I bet you also did not evacuate the sytstem to remove any air.
Unplug the pressure switch at the dryer and jumper the wires. This should engage your clucth so the compressor will draw in the refrigerant as the engine is running with the A/C on.
Old Feb 3, 2011 | 11:31 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You've got oil in your orifice which is stopping the system up. Drain it and start over.
Galaxie500XL
Feb 1, 2020 04:53 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
customblackbird
Oct 1, 2015 04:30 PM
CatmanFS
Sep 19, 2015 09:00 AM
