Cant connect tranny lines to new radiator?
Old Mar 12, 2011 | 07:55 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
So my radiator cracked today and i went ahead and bought another one, everything was smooth but i cant seem to get the transmission cooling line fittings to screw into the radiator slots.
Is there some sort of trick to getting the lines in?
I keep trying and trying and the fitting just spins and never catches on, sometimes it feels like it finally caught on but then just spins back out.
I compared both radiators and they both have the same slots, even tried putting my old one back on and i couldnt even do that.
So what am i missing? thanks for any help.
Old Mar 12, 2011 | 08:08 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Cant connect tranny lines to new radiator?
could be stuck on the o-ring, may need to push it in farther (although it feels like it's in all the way), or you could be at a slight angle, i've had that happen before. Best I can say is run the part number to double check you got what you wanted.
Old Mar 12, 2011 | 11:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you have to get a nice straight shot, gotta man handle the line around till it lines up right, when it does, it will go in.
Old Mar 13, 2011 | 01:11 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup basically thats it. they can be tricky sometimes.
Reddeath210
Oct 6, 2015 08:20 AM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
