pulley system
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
pulley system
ok guys do anyone have a custom pulley system on the third gen? i want to go with a billet set of pulleys, but they tell me that if i want to keep my reverse rotation water pump then nobody makes a set for our cars? can anyone help out with some info or distributors that sell what im looking for, ill add a few pics of standard rotation from march. remember i want to keep my reverse rotation!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: pulley system
The ONLY reason you have the reverse rotation water pump is because of the serpentine belt setup. Get rid of the factory serp bracket system (which is ugly anyway to me), and you HAVE to use a regular rotation water pump. Not a big issue since water pumps are cheap. Swap any pulley/bracket setup you like.
I'm using a $30 Mr. Gasket alt bracket in chrome, moved alt to pass side where it belongs (in my world), I'm using a March p/s bracket. I have a serp belt from crank to w/p to alt, and I run a V belt from crank to w/p to p/s pump (a kind of 1/2 and 1/2 system like the 1987 cars have). Of course I have no smog pump or A/C anymore.
Car: 1992 RS
Engine: Carbed 350
Re: pulley system
Can see a few pics in my photobucket - but hard to take pics with the front of the car in the way
http://s287.photobucket.com/albums/ll121/jw_baum/92RS/
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
