Stock radiator cool enough?
Car: 1983 Z28
I am in the process an engine swap. It will be a 355 with aluminum heads. I have a dual fan setup from my TPI donor. Will a stock replacement radiator be enough or should I upgrade? I do plan on upgrading the water pump.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Stock radiator cool enough?
Stock fans will be fine. I'm running a single TBI fan on my 350 with stock 305 radiator, and it cools it fine.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Old post. I installed a 355 in my 84 T/A as well. I've found my Single electric fan doesn't keep the car cool when the AC is on, otherwise it works just fine.
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
I have stock dual fans and radiator and it works perfectly, the owner before me was an idiot and wired the fans backwards and made it so they were blowing air and not sucking it through the radiator
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
