Overheating HELP!!!
Old Mar 20, 2011 | 09:02 PM
35085TA's Avatar
Overheating HELP!!!
Hi,
I have a 1985 trans am and i have a questions,
the car has a chevy 350 motor (i dont know were the motor came out of) its carbed and has some mods it has,
Flat head pistons
street cam
edlebrock intake,4 barell carb,headers
and an electric fan
Over the winter we started the car and forgot to turn on the fan so it overheated we tried to shut off the car but it wouldnt so we stalled it out in 2nd...
sience that day the car is getting up to 230 dagrees f
we have replaced the thermostat,radiator,and the water pump (new one)
today we let it idle for about 1hr and it hit 230
we checked the oil and i see no grey and there is no antifreeze coming from the exhaust so i dont think its the heads but
plzzzzzzzz
Old Mar 20, 2011 | 09:22 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Overheating HELP!!!
Is the fan coming on at all? Also if the sender for the temp gauge is not compatible ( not the same year as the gauge/cluster) it could be way off
Old Mar 21, 2011 | 04:17 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
it wouldn't shut off? ^^
as stated, fan info necessary to troubleshoot this any further.
you say it has an edelbrock intake, dunno if you use it but if it does have a Coolant Temperature Sender you can also read it out with an ohmmeter instead of relying on the temperature gauge (though the CTS might also be shot LOL).
Old Mar 21, 2011 | 10:56 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
230 is not overheating. Unless the coolant is boiling over, it's not overheating. These gauges are not very accurate at all.
As asked, is the fan running?
Old Mar 21, 2011 | 07:46 PM
35085TA's Avatar
thanks for your time and input ,
Yes the fan is running
also the anti freeze inst boiling over im just concerned about the temps
again thanks!
Old Mar 21, 2011 | 07:49 PM
35085TA's Avatar
i dont have a censor, the only thing i have is a copper cupler going into the block that's hooked up to a gauge inside the car (sunpro)
the car will shut off it disealing a little then it shut off
Thanks for your reply
Old Mar 21, 2011 | 07:51 PM
35085TA's Avatar
Yes the fan is turning on we also have two gauges one sunpro and one in the radiator cap the one in the rad is saying 180 and the sunpro one is saying 230 i dont know what one to believe
Thanks for the reply
Old Mar 21, 2011 | 07:57 PM
Car: 1992 RS
Engine: Carbed 350
I wouldn't believe either. Stop in a a local shop and ask a mechanic to shoot it with infared temp gun and see what it really is.
If the car is dieseling, need to check timing.
Old Mar 21, 2011 | 08:57 PM
35085TA's Avatar
k thanks i think i will
it only dieseled twice but we are gonna check the timing
would that cause it to get hot ?
Old Mar 24, 2011 | 03:47 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
If your timing is off, it could cause it to run a little hot. Just for a figure of reference, I have a jet fan switch that turns my fan on at 195*, my temp gauge when it turns on is just past the 220* mark on the temp gauge in the car. So your gauge could be off by quite a bit. So long as the car still runs fine and isn't boiling over, there is no water in the oil or vice versa, I wouldn't worry about it too much.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
