Heater hose question
Old Mar 24, 2011 | 06:40 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Im replacing the heater core on my 89 rs. I just did this on my 87 but the hoses ran a different route. Does anyone know what the driver side hose runs to? It goes down the firewall behind the engine. Its a 90degree bent almost and runs about 6 inches till it connects to a metal hose maybe? Im wondering since i cant get it off, if I just cut it will it be a bigger pain to get a new one on? It seems like there is no room to get down there unless maybe I jack the car and try from the bottom.
Old Mar 24, 2011 | 06:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Heater hose question
That metal tube, pass side right? It's just a tube - you can cut the hose off and just use a longer hose if you like - there's nothing special about it - just GM's attempt to hide one hose out of the way.
Old Mar 24, 2011 | 07:03 PM
StringRust's Avatar
no, it's behind the engine on the pass. side. Rubber hose from heater core and runs down to something that I cant see. Feels like a metal hose but Im assuming if I cut it off I will never get a new one on because I can barely get my small girly hands back down there. Im thinking I should just keep struggling like hell to rip it off the heater core till it breaks and I get pissed and then have to replace the entire hose anyway. haha
Old Mar 24, 2011 | 07:49 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
girly hands?
Old Mar 24, 2011 | 08:08 PM
StringRust's Avatar
yup. dont get too excited, just a dude with girly hands.
Old Mar 24, 2011 | 09:17 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
That hose does attach to an aluminum pipe. It runs along the the body rail forward to either the engine oil cooler (if equipped) or just into the rad. Your best bet is to slice the hose longways, then it will just fall off of the fitting, then replace it with a new rubber hose.
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
redmaroz
Aug 16, 2015 11:40 PM
