Turn A/C Off and Car Dies
Old Apr 5, 2011 | 09:46 PM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
Axle/Gears: G92 3:23
hello guys like the title says i turn off the a/c and the idle drops then the car dies, i dont have any idea whats wrong ,has any one had this issue before? and what was done to correct the this problem.any help would gradly be appreciated.thanks
Old Apr 7, 2011 | 07:24 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Turn A/C Off and Car Dies
What engine is in your car?
The only real thing I can think of is that the earlier model thirdgens with rochester carburetors have a solenoid that bumps the throttle lever up, so when the AC is on the engine doesnt drop in RPM's too drastically. Maybe your idle is just too low to keep the engine running while that solenoid isn't engaged? I am not sure what engine your car has, or what year it is so I am just taking a shot in the dark on this one.
Old Apr 7, 2011 | 08:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
All the cars had a throttle increase mechanism of some sort for the A/C - later cars got it from the ECM bumping up timing or fuel from readings on the high pressure switch in the A/C line.
Old Apr 8, 2011 | 12:55 AM
onefreakz's Avatar
Car: 92 camaro z28
Engine: 5.7 tpi
its on my 89 camaro 305 tbi, my guess is the IAC i notice today when ever i come to a stop idle drops and acts like it wants to die then the idle comes back up 500rpms
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
