blower motor question
Old May 5, 2011 | 10:33 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
hey all on this 86 iroc I'm going to replace my blower motor, it has 2 spade terminals on it, and the replacement one only has 1.do I just ground the other one? any suggestions greatly appreciated
Old May 5, 2011 | 10:36 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: blower motor question
You go without AC and consider it weight reduction.
Dunno. I'd ground it and see what happens. But seriously, yanking that compressor can take some decent weight off of the front end!
Old May 5, 2011 | 11:26 PM
jeff_blake's Avatar
yeah I know. that's a project for another day. blower motor doesn't work, no heat. mornings here are still a bit chilly
Old May 6, 2011 | 12:09 AM
jeff_blake's Avatar
well wasnt the blower motor, or the relay. least i know there both new lol. any ideas?
Old May 24, 2011 | 02:11 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
What are the problems you are having..? No heat? or No heat AND no a/c..? Stone
Old Jun 4, 2011 | 02:36 AM
jeff_blake's Avatar
sorry stone, been away for awhile. you turn it on, noting at all happens. i replaced everything but the resistor, in which i cant seem to find the right one.
Old Jun 4, 2011 | 02:45 AM
jeff_blake's Avatar
the one i have in there is different from factory i think, its got the 4 prongs. same shape as factory. but factory has the 3 prongs with 3 prong plug. one that was in there seeems to be out of an 1984 Oldsmobile Cutlass Calais 5.0
Old Jun 4, 2011 | 01:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Have you checked the fuse or, for power at the resistor ?
It is possible the fuse could be bad or, the fan switch inside the car is no longer working.
Old Jun 5, 2011 | 10:59 AM
jeff_blake's Avatar
yeah fuses are fine, it has new blower motor, relay, resistor, switch. not getting power to it seems reasonable
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
redmaroz
Aug 16, 2015 11:40 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
