thermostat bolt snapped. best removal?
Old May 12, 2011 | 06:38 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
So it seemed as if my thermostat was stuck because the water wasn't flowing through very well and the car would get hot at red lights. So I went to remove the hose and the damn bolt snapped. There is about 3/16 of it above the manifold. What would be the best way to remove it? It seemed as if it was cross threaded.
Old May 12, 2011 | 07:46 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: thermostat bolt snapped. best removal?
I'd soak it everyday in PB Blaster for a few days, and then maybe try a pair of vise grips on it.
Old May 12, 2011 | 07:48 PM
Car: 91 RS T-top
Thanks but I'm at work and its my DD. So I'm stuck here until its fixed.
Old May 12, 2011 | 07:57 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Lesson number one. Never work on your car anywhere else but home unless you work at a shop.
That being said, heat it with a torch till its cherry and hit it with some penetrating lube this usually draws the lube into the thread area much like if you where sweating pipes at home. Drill it out enough and use a bolt thread extractor. If you don't have any, some locking vise grips may work.
If that doesnt work, drill it out clean and re-thread it with a tap. It looks like it has seen better days maybe a new manifold would be a worth while consideration.
Old May 12, 2011 | 08:06 PM
Car: 91 RS T-top
Yea that was my first thought. Why the hell didn't I wait to check it this weekend. I figured two bolts check the thermostat and if it needed a new one I'd get one Saturday. Instead this crap happened. I will try heating it up with a butane torch and use vise grips. If I can't get it tonight, hopefully our maintenance man will let me borrow the welder for a few seconds and I will attempt to weld a nut on it and see if I can un screw it then. Thanks
Old May 12, 2011 | 08:18 PM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
I did that on my truck once and just said screw it and dropped some dough on an edelbrock manifold.
Old May 12, 2011 | 08:27 PM
Car: 91 RS T-top
Just don't have extra cash at the moment or I probably would. Living on your own has a few set backs ha ha.
Old May 12, 2011 | 08:45 PM
Car: 1985 IROC-Z
Engine: 355
If the original head snapped that nut off you will not be able to weld a nut that will hold on that rust. You will most likely have to drill it out, the treads are most likely trashed on the inside anyway. You will have to re-thread it once you get it out.
Old May 17, 2011 | 06:24 PM
Car: 91 RS T-top
Thanks for the help I had to just drill the bolt out and retap
Frozer!!!
Jan 19, 2024 04:55 PM
Eric-86sc
Apr 3, 2016 03:52 PM
theurge
Aug 21, 2015 12:46 PM
perZ
Aug 15, 2015 01:17 PM
3rdgenparts
Aug 8, 2015 07:09 PM
