Need a Fan
Old May 16, 2011 | 03:14 PM
pvr007's Avatar
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Need a Fan
Hello, my Camaro i just bought didnt come with a fan, so i have to buy one, heres a listing of the current options i have, please guide me to the best option
http://cgi.ebay.com/ebaymotors/2X-12-BLUE-RADIATOR-FAN-MOUNT-REGAL-GN86-SKYLARK-F-1-/220781902877?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro|Make%3AChevrolet|Year%3A1988&hash=item3367a07c1d
im not sure if this one even has a motor
http://cgi.ebay.com/ebaymotors/1988-CHEVY-CAMARO-RADIATOR-FAN-ASSEMBLY-/220764523838?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro|Make%3AChevrolet|Year%3A1988&hash=item3366974d3e
this one looks more Original
http://www.autozone.com/autozone/par...8_111184_7523_
or this one from autozone, this one, it says something about compressor,
now i know that i will also need something else, like a sensor or something, right? please help me i am clueless on this, i will take ditailed photos if you need me to
Old May 17, 2011 | 12:51 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Need a Fan
Ok none of those are the Original style fans. The 2nd option would have to be modified to even fit. The first and third options are both universal fits. I would run the dual fan setup because they cover more of the radiator and therefore pull more air thorugh it to cool it down. Now you have to measure your radiator and get the fan measurements to make sure it'll work properly. I am assuming you have the upper radiator mount? the stock fan bolts onto that. You can also find a stock setup at a junkyard.
Old May 17, 2011 | 12:57 AM
pvr007's Avatar
Engine: 305 TBI
Re: Need a Fan
well currently the radiator is off, i only have the oil cooler in there, so i guess ill make some measurements and find that piece, thanks, ill take some pics and upload them tomarrow night
Old May 17, 2011 | 09:17 AM
chevysquid's Avatar
Car: 1986 IROC T-TOP
Transmission: 700-R4
Re: Need a Fan
Good always go with a mechanical fan too.
Old May 17, 2011 | 11:50 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need a Fan
Mechanical fan? Why? Get so much better cooling with an electrical fan. Besides, 1988 cars didn't have a mechanical fan option - they were all electric. Mechanical fan requires a shroud, different water pump setup maybe (1988 car has serpentine, so a reverse flow water pump) ... ie too much trouble for less cfms.
Any aftermarket fan that fits the radiator will be fine - get the most cfm's for your dollar. Even the stock fan is fine if you have the factory top and bottom pieces to bolt it to. Otherwise, all the aftermarket fans usually come with ties that run through the radiator fins to 'strap' them directly to the radiator.
I'd also highly recommend a seperate fan controller, adjustable if you can afford. They probe the radiator, don't use any of the factory wiring, and work so much better than the factory fan switch/relay set-up. I run a Flex-a-lite model, $90 with all the bells and whistles it has, but well worth it.
Old May 17, 2011 | 12:34 PM
pvr007's Avatar
Engine: 305 TBI
Re: Need a Fan
but wont i need the sensors and all those things?
Old May 17, 2011 | 01:28 PM
Car: 1992 RS
Engine: Carbed 350
Re: Need a Fan
Not with a seperate fan controller - it comes with a probe that sticks inbetween the rad fins to get temps.
Old May 17, 2011 | 02:12 PM
pvr007's Avatar
Engine: 305 TBI
Re: Need a Fan
ohh so how much those cost?
Old May 17, 2011 | 05:01 PM
Car: 1992 RS
Engine: Carbed 350
Re: Need a Fan
$40 - $100+. Here's the one I run: http://www.summitracing.com/parts/FLX-31165/?rtype=10 (price went up a bit since I bought it). Flex-a-lite makes several different ones, price comes down to the bells & whistles. Basic models available on the shelf at autozone/advance/whatever, but generally not adjustable.
Old May 17, 2011 | 11:42 PM
pvr007's Avatar
Engine: 305 TBI
Re: Need a Fan
nice, ill buy it as soon as i can, also, mmm i see theres no fan, could you help me buy some, im not sure what to buy
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
