overheating/airdam/cooling rebuild
Old May 22, 2011 | 11:13 AM
VelocitySc0pez's Avatar
Car: 1991 Camaro RS
Engine: 305 V8 TBI
Ok, I've posted like 4 times this last week about all my cooling issues with my 91 RS 305 tbi and i truely appreciate all the help from everyone. for anyone that hasn't heard my story, the short version is I have lots of cooling problems and my radiator blew and im planning on doing a full cooling system rebuild. Here's my plan after my next paycheck. Just let me know if im leaving anything out.
1. flush the entire cooling system. Get everything out of the motor and radiator. even air.
2. install new radiator $150-$200
3. install new thermostat $17
4. install new waterpump $20
5. Airdam!?!? -need help with where to find one and how easy are they to install?!- but I want that taken care of.
6. Install new fan motor.
And I should be all set..? Right..??
Old May 22, 2011 | 11:31 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: overheating/airdam/cooling rebuild
If the water pump & fan are working, I would not replace them. However: you forgot about your hoses. The air dam should be easy to locate and install. The mounting hardware should still be on the car. The airdam was standard on all 3rd gen cars and the most important item for cooling system.
Old May 22, 2011 | 11:45 AM
Car: 1991 Camaro RS
Engine: 305 V8 TBI
this is a sloppy picture but it doesnt appear I have an airdam as i can see all the way down the ways of my car without anything that looks similar to an airdam blocking the way.
Maybe the previous owner removed it? Maybe it fell off?
How do I go about finding one? and it looks like installation wouldn't be an issue at all so i wont worry about that.
Old May 22, 2011 | 11:58 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You probably only needed to do step 5 in the first place, these cars have no grille, how else does it get fresh air? you think the fan is gonna do it all on its own.
probably spent money not needed.
Old May 22, 2011 | 12:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Make sure the baffle is there as well.
JamesC
Attached Thumbnails overheating/airdam/cooling rebuild-img_0191.jpg
Old May 22, 2011 | 12:25 PM
Car: 1991 Camaro RS
Engine: 305 V8 TBI
I haven't spent a dime yet.
My fanmotor is shot.
My radiator is blown.
My thermostat isnt opening.
and the waterpump most likely needs to be replaced.
explain to me why I'm wrong again please
Old May 22, 2011 | 12:27 PM
Car: 1991 Camaro RS
Engine: 305 V8 TBI
JamesC
thank you, I will. much appreciated.
Old May 22, 2011 | 02:02 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Not knowing where you are located or whether you are in to looking at and crawling around the Junk yard, here's what it looks like and one possible source. May be one closer to you?
http://www.moderndaymuscle.com/inc/sdetail/163/793
Old May 22, 2011 | 02:34 PM
one92rs's Avatar
Car: SOLD!!!!!
rebuilding the cooling system is fine. get a new airdam or a good used one. on the water pump something you might want to check. i have a 1992 rs tbi. replaced the water pump with the regular water pumps from 3 different manufacturers. the belt squeaked. it drove me nuts for a while since it was sort of centered. i also had a smaller squeak before i replaced mine. i finally began measuring the belt difference between pullies. 1/16. i ended up going with a gmpp water pump and it measured perfect. no more squeaks.
Old May 22, 2011 | 10:14 PM
Car: 1991 Camaro RS
Engine: 305 V8 TBI
is this the cheapest one around
Old May 23, 2011 | 07:42 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
An airdam is a bid deal, when I explored a front spoiler, even though it was half open, very first thing my temps went right to the moon as it blocked the air, to the airdam. The spoiler came right off.
Old May 23, 2011 | 11:55 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
look at thirdgenranch, i got my airdam from them for $15 used, but they have NEW ones for $30
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
