coolant temp gauge problem
Old May 24, 2011 | 08:03 PM
92z28outlaw's Avatar
Car: 92 Z28 Z03/89 IROC
Engine: MIA/mild 350
Transmission: MIA/T56
Axle/Gears: 3.28/3.73
I need a little with my 92 z28, my gauge is being a pita,I picked up a new sensor and nothing still. the needle on the gauge moves when I turn the key into the acc position, and it pegs when I ground the lead
I'm sure it's something stupid i just need some insight.
Old May 24, 2011 | 08:14 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: coolant temp gauge problem
did you replace the sensor or sender?
Old May 24, 2011 | 08:31 PM
I always thought the sender/sensor is the same thing. too be more specific, I replaced the coolant temp sender that threads into the driver side head
Old May 24, 2011 | 08:45 PM
Engine: L31 350
behind the ac compressor? and these cars have 3 sensors or atleast my car does. i have 2 on the intake and 1 on the head, the one of the head is for the gauge, the two on the intake are for the ECM
Old May 24, 2011 | 08:48 PM
Engine: L31 350
http://www.autozone.com/autozone/par..._&sortType=low
Old May 24, 2011 | 09:12 PM
the sensor I replaced is the gauge sensor in the driver side cylinder head.
Old Jan 28, 2012 | 03:44 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
if you read many of these posts,you begin to realize most, if not all of us have a bum temp gauge.they are still available however GM #25034460
Old Jan 29, 2012 | 10:17 PM
yeah, could be the case. i will get one from another cluster and we shall see
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
TheExaminer
Aug 26, 2015 04:59 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
