Retro fit kit r-12 to r-134a
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
Ok so i have recived several different answers on this
I have the old r-12 sytem that doesnt work. I am thinking of purchasing the retro fit kit from autozone to put r-134a into it. Some people said that plain wont work. Some said you have to vacum out the old stuff first and it will. Some said it will never work. What should i do? (besides rolling down the windows i hate that answer)
Thank you
Thank you
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Retro fit kit r-12 to r-134a
It will definitely work if you do it right. There are instructions on the box and a bunch of articles and videos on-line. Google/Bing it. You'll probably want to replace at least a couple of parts (orifice tube and drier). Read first.
Car: 1983 G20 Chevy
Transmission: 4L60
I definately disagree, the stock R12 system will cool very poorly at slow speeds and only provide ample cooling at highway speeds when using R134a. The condensors are constructed wrong for R134a and too small, the cooling fans inadequate, the orifice too large, and the pressure switch adjusted wrong. Fix these short comings and it will cool well.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
What exactly do you disagree with? Doing it right, following the instructions, reading the articles, watching the videos or replacing necessary parts? Whether it's worse than, as good as or better than original is another issue. DIY is cheaper up front than a professional conversion. You just assume the risk.
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The orifice tube should be swapped and a new drier would be a good idea. After the adapters are put on then a put a good vacuun on the system for 20-30 min. Fill with the proper amount of 134a and should be ok. One thing to keep in mind is that 134a runs at a higher pressure so if the compressor is weak it will not last long at all. I do not remember for sure but I believe it would take 75-80 % 134a as compared to r-12. The compressor oil may or may not be compatible with 134a. 134 a is a lot smaller molecule than R12 so any leaks from R12 will be magnified.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
The cycling switch needs adjusting too. 1/4 turn? Can't remember which way. I read it somewhere. Google?
Car: 1983 G20 Chevy
Transmission: 4L60
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
