Does LT1 require new radiator?
Old Jun 20, 2011 | 06:19 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
i have a 85 z28 305 TPI and i was wondering if an LT1 swap requires a different radiator than the stock TPI radiator.
Old Jun 20, 2011 | 06:30 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Re: Does LT1 require new radiator?
No, you don't NEED it... But if it were me I'd rather have it. Besides the ac condenser and fans go with it.
Old Jun 20, 2011 | 06:50 PM
n8sz28's Avatar
Car: 85 camaro z28
I need to buy a new radiator now because mine went out need to get the 305 running again. However if I buy a new one now I rather get a nice aluminum one but want to be able to use it when I do about engine swap in the future. Any ideas of what the best thing to do is
Old Jun 24, 2011 | 11:04 AM
Firebat's Avatar
No, does not require new radiator. Others have used the stock thirdgen radiator in LT1 swaps and its just a matter of finding out which top and lower hoses to use. Most like the LT1 radiator setup because of how nice and inexpensive the dual fan setup is vs the thirdgen dual fan setup.
Old Jun 24, 2011 | 11:07 AM
n8sz28's Avatar
Car: 85 camaro z28
Ok thanks
Old Jun 24, 2011 | 11:15 AM
supr_fly03's Avatar
Car: 83 Z28
Engine: F-body LT1 swap
Transmission: T-56 swap
Axle/Gears: 10 bolt w/ 28 spl posi, 4.10, disks
I run LT1 fans on my 3rd gen radiator. I am fighting an issue with it getting hot at low speeds, but most time it stays around 170.
Old Sep 25, 2011 | 02:35 AM
kukerdan's Avatar
I am fighting a similar issue.. gets real hot real fast at low speeds .. check my post https://www.thirdgen.org/forums/ltx-...fast-when.html
Old Sep 25, 2011 | 04:21 AM
GTAStockholm's Avatar
Car: -88 Trans Am GTA
Engine: 305TPI / 456hp 383cui
Transmission: T5 / T56
Axle/Gears: 3.45 9bolt
In my Lt1 swap i use 3gen radiator and it works fine! No heat problems in any speed. (my car have dual fans standard)
I use Corvette c4 94 lower hose, and Camaro 94 upper hose.
Sorry for my mix with Swedish/English
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
jrdturbo
Mar 31, 2016 02:58 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
