View Poll Results: Whats Wrong with my Cooling System???
Hoses are hooked up wrong/Need to be switched
16.67%
Air Pocket in block or cooling system
33.33%
2 Faulty Thermstats?
0%
Somthing else (please Post !)
50.00%
Voters: 6. You may not vote on this poll
LT1 Overheating FAST when driving but cool if just idling
Old Sep 25, 2011 | 02:18 AM
kukerdan's Avatar
(96 impala SS LT1 [EGR-AC-TB Coolant Delete], NEW 3rd gen Z28 5.7 Radiator)
Heres my questions for anyone who doesn't want to read the full thing. VOTE !
A. LT1 Waterpump 92 Z28 3rd gen Radiator.... WHERE SHOULD THE HOSES BE GOING.
B. IF THE HOSES ARE HOOKED UP CORRECT... COULD AN AIR POCKET BE CAUSING ALL MY MISERY.
please read on if you can...
Here is my issue...
I thought I was going to drive my baby home today from the shop finally.
88 camaro.. 96 lt1
Its a stock 3rd Gen 5.7 Z28 replacement radiator and my lt1.
I bought the recommended pump-to-rad hoses a long time ago.. Something like a Z28 upper and a mustang lower or vice verso.. something like that... Whatever guide I followed I Bought The suggested hoses. They fit just fine.. although not perfect.. we have em zip tied up a bit cause they are just a big too long.. maybe that's cause we got em backwards?
A few days ago my cooling issue was this....
Idle or driving around (albeit VERY short because of the over heating)
The Rad is COOL to the touch... No hot engine coolant flowing through.
So my mechanic and I thought it was a bad thermostat.... So I put a new stant 180 lt1 thermostat and a new duralast Temp sensor for right there...
And took and smoke break and let it idle for like a half hour... the temp gauge finally got to about 180... the radiator was getting warm/hot to the touch... and a few mins later. (i have 92 z28 dual fan setup) both fans kicked on.. the temp gauge went down a bit, and it held that happy medium... I thought I was home free...
I go to drive home.. within a half mile or less, totally babying the car; I look at the temp gauge and its almost maxed.... I looped around and went right back to the shop barely touching the pedal, and the gauge was past its highest point My Overflow tank was FULL and pissing from under the cap it was so hot...
THE RADIATOR I COULD LAY MY HAND ON IT WAS LUKE WARM AT BEST ALMOST COLD .... Why Did it not flow like it was when it was idling?
My mechanic is boggled...
I think he may have hooked the hoses up backwards?
The throttle body has none of that coolant stuff. I bought a bypass kit, and a Billet IAC housing with no hoses or any of that TB coolant garbage.
Theres no heater hooked up at the moment.... There are no leaks except when this overheat happens and my overflow tank OVERFLOWS!@
if the hoses are hooked up the right way from the pump.. what could it possibly be?
I looked at a few posts that were somewhat helpful but I cant find a real great pic of LT1 waterpump and hoses going to a 3rd gen radiator.
If its a simple explanation llet me have it!
thanks guys... Im almost home free.... I just CANT drive this dying Honda anymore, its so depressing to have that LT1 machine and I cant drive it
Old Sep 25, 2011 | 02:26 AM
BillyTheGoat's Avatar
Car: 1989 Trans am
Re: LT1 Overheating FAST when driving but cool if just idling
is your air dam there
Old Sep 25, 2011 | 02:30 AM
kukerdan's Avatar
no its not... but I was just going down 30 mph roads.. and it took like 2 minutes for it to happen... I will reattach the dam... but my rad wasnt even hot, like the coolant wasnt flowing thru it
Old Sep 25, 2011 | 02:53 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Try with the dam. It will overheat without it, nothing severe but it will. On my test drives my temps got around 239 without it.
The hoses are simple, Passenger to passenger and driver to driver. Nothing to get mixed up.
Old Sep 25, 2011 | 03:06 AM
kukerdan's Avatar
I will try the dam... but the radiator was cool..... i could put my hand on it... and my temp gauge was beyond maxed out... the dang needle wanted to spin around again..
Lukily I have a nice oil cooler hooked up, and it was real hot... probably saved my ****
Old Sep 25, 2011 | 09:42 AM
kukerdan's Avatar
Its just about 11 am,,,,, I am going back down to the shop (30 min ride
To try and figure this out!!! ill be there for hours..... any input in the next few hours would B critical.
THANKS!!!!!!
Old Sep 25, 2011 | 09:52 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
the order of hoses from the waterpump is:
heater out
heater return
upper rad hose
lower rad hose
cap off oil cooler fitting
I remember my 305 did the same thing, thermostat worked for like 5 min before overheating. But i had flow to my radiator. try getting some radiator flush from autozone and spend a half hour or so flushing it with the hose(make sure your motor is cool first, dont want to crack any parts)
Im not sure if the air dam is the issue here, it seems to be heating up too fast for that, sounds like crossed hoses or a really clogged cooling system
Old Sep 25, 2011 | 11:55 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Are any of the hoses hot? If not has anyone ever had the water pump off? Maybe they forgot to put the water pump drive shaft back on when they put it back on.
Old Sep 26, 2011 | 02:46 AM
kukerdan's Avatar
5$ Stant Radiator cap fixed the issue.... For some reason my radiator cap was shot.. or someone switched it...
We put the bleeder on and let it idle in the bay for a few hours... burped bubbles for a bit.. then stayed right at 190...
Drove her home and all around today... runs and drives AWESOME..
Saturday Front Drilled.slotted Rotors and ceramic pads go in.. and my Le1 Ac delete heater box.. Ill start cleaning up some of the extra wiring too, and hook my MIL up instead of a blinker bulb under the hood (works 100% tho)
NO codes... and I havent found any kind of limit yet.... gonna have to take it to a track or do somthing naughty
I will put pics on flikr and post soon. thanks!!
Old Oct 7, 2011 | 11:40 AM
55ChevyMan's Avatar
Car: 55 chevy Belair & 86IROC Z
Engine: 350 in 55 86IROC Z LT1
Transmission: 55 4speed IROC Z4L60e
Axle/Gears: 12 bolt 410 in55 and 342 inCamaro
I got the same problem 86 IROC Z 94 LT1 swap and no mine has less then 35 miles and no airdam it stared overflowing the coolent I pull over at gas station and let cool down and added water just to get it home what the thing on the hoses I have heater hoses connected and I am using the stock water pump and a buick roadmaster overflow pressure tank and where dose the air dam go on below the radiator? also can anybody tell me, I have the 86camaro daul fans with( two fan relays these must have a fuse where is it located, I was think of puting a Hayden 3652 so fan come on at 185temp
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
sreZ28
Aug 14, 2015 07:48 PM
